    Mar 2011
    5
    Bulk milk tank insulation
    Does anyone know how well insulated refrigerated bulk tanks at dairies typically are? I'm looking for the thickness or R-value of the insulation between the two walls. I can find that the space is filled with polyurethane insulation, but not how much.
    I'd be interested in differences in insulation between older tanks, as well as new tanks.
    Thanks.
    Sep 2003
    ISRAEL
    72
    4,248
    Re: Bulk milk tank insulation
    The insulation thickness should be 50mm of polyurethane 40kg/m³.
    Mar 2011
    5
    Thank you.
    Auckland
    74
    3,357
    37
    Hi cjroos.
    google NDA Engineering.co .nz NZ is covered with tanks, vats, tankers and silos etc., for milk.
    You may find some info on tank insulation. [ NDA is for National Dairy Association. ] they generally spec everything.
    Mar 2011
    Australia
    43
    67
    14
    NDA vats were known to crack internal welds due to poor design. This took me 16 hours to repair at farmers expense. I have not worked in the dairy refrigeration industry for many years, hopefully NDA milk vats and service has improved.
    NDA vats had 350mm of insullation in bottom of vat, cooling dimple plate sloped for CIP drainage and tanker drainage therefore insulation would change through bottom of vat wall thickness was constant vats were silo type (vertical).
Tags for this Thread
