Results 1 to 1 of 1
01-04-2011, 01:15 PM #1
Maintenance Tips for Refrigerators
Hi All,
I am Sam. I am an owner of an electronic shop. We provide all refrigeration appliances and their maintenance service. I would like to share some tips to maintain a refrigeration system at home. I hope this will help you:
• Firstly, check the gaskets. Gaskets are very important and play an important role to keep the food and drinks cool. If they are dry or get cracked, this will increase the energy consumption rate and also reduce the efficiency of system.
• Refrigeration system should be clean always. You can stick a vacuum layer on the refrigerator. This will prevent the entrance of dirt, dust and dead critters.
• If you have pets at home then you have to pay special attention in the cleaning process. You have to clean the complete system once in a month.
• You should also check the place where the refrigerator is placed. That place also should be clean.
Also check the manual for instant results.
______________________
Refrigeration Maintenance
