Results 1 to 16 of 16
Thread: Cold store "book"
19-09-2005, 10:08 PM #1
Cold store "book"
Hi mates , anyone can point me to a book that contains the exact methods of selecting cold rooms system components and contains a comparison between different methods of load calculation
Thanks for help
19-09-2005, 10:58 PM #2
Re: Cold store "book"
Or,.... you could spend a vast sum of money and buy the latest software...
perhaps not but have a look anyway.. http://www.coolit.co.za/coldroom/Brian - Newton Abbot, Devon, UK
19-09-2005, 11:44 PM #3
Hi Brian , thanks for you reply . . .
Unfortunably , i need a book for teaching purpose
But i do have almost the same software (in french) and for free , it's developped by a Phd french professor and it's totally free with the same options as the one you pointed me to , it's called (charge frigorifique) so if you are interrested , you can email me or say that here
And guys the offer isn't limitted to Brian , anyone who wants it just post your emails and you will get it for sure . . . but again it's in french
Best regardsLast edited by botrous; 19-09-2005 at 11:52 PM.
20-09-2005, 12:55 AM #4
Hi guys,
Here is some additional information and places to look at for load calculations for storage or cooling:
http://www.heatcraftrpd.com/software/software.htm
http://www.elitesoft.com/web/newsroom/refrig1.htm
http://www.fao.org/documents/show_cd...e/V3630E09.htm
http://www.ba.ars.usda.gov/hb66/012heat.pdf
http://www.climaticcontrol.com/info/...c_21(rev1).htm
Some of the above are advertisements for software , other links have some solid information.
Hope this is useful.
Regards,
US Iceman
20-09-2005, 01:07 AM #5
Hi Botrous,
The only "book" I am aware of for load calculations is available from Krack Coil here in the US. They have a very nice and simple method used for this purpose.
Their website address is:
http://www.krack.com/
The book was recently republished for the first time in many years. Perhaps you can send them an email and see if they will send you copies, or, a PDF of the book.
If I think of any more sources I'll let you know.
BTW, can you send me a copy of the heat transfer information you got from Carlos Hansen (I think I spelled this right, my apologies if I am mistaken)?
Regards,
US Iceman
20-09-2005, 02:48 AM #6
Originally Posted by Botrous
I think the most complicated part is heat influx through doors and truck ports etc. As this newer will be exact anyway, it may be better - definitely easier - to use an air change factor.
Saludos,
Jan
20-09-2005, 06:21 AM #7
Hy everyone
I already have get it the coldroom de luxe, from info coolit since dec 2004.At that date they have for free a demo version .I don't now if is available and now but make a try.
20-09-2005, 11:02 AM #8
If it is for teaching purpose shouldn't you make your own program in Excel or similar, so it easy to se the different loads. You can then use the commercial programs to "verify" your calculation.
RegardsEngineering, sciences, math, physics and my brain will generate "not responding " soon
20-09-2005, 11:04 AM #9
Regards,
US Iceman
And man thnaks for the links your provided , some are good , the others as you said jud ads
RegardsLast edited by botrous; 20-09-2005 at 11:17 AM.
20-09-2005, 11:20 AM #10
Hello IceMAn..
HeatCraft have the best engineering manual not only the load estimation software..it is called Engineering Manual (H-Eng1) Puplished June 1990 i think they have revised that, it have all the fundementals, besides the ASHRAE handbook (Both Refrigeration & Fundementals) but it is complicated a little bit than the hearcraft..
regards..Too Much Of Something Is Bad Enough
20-09-2005, 02:36 PM #11
Hi Guys,
Botrous makes a very good case against using software. I have seen a tendency for newer people to rush out and buy software to solve their problems.
After all, it is much faster to use the software rather than to use a pencil and paper.
However, it is my opinion that using software to learn a subject is very dangerous. Students (or less experienced persons) tend to assume they understand what the software input data is. Another problem is that the program supplies "answers".
I had a friend who was a structural engineer. A younger co-worker used a program to size steel for a building. When the young guy was finished with the program he said, here's the answer!
The problem was, the steel he selected had sufficient strength, but it was too flexible. You will see this is new office buildings sometimes. The floors feel like they are bouncing. Right answers, wrong results.
A program only crunches numbers. Numbers IN, Numbers OUT. And... the program is only as good as the person who wrote it.
People should have a good understanding of the methods and logic used to develop an answer. The best way to get this is to do repetitive hand calculations using an accepted method.
You have to develop a "feel" for what the correct answer is. I call this a sanity check.
Some of the ASHRAE material can be a intimidating since it was basically written by professors for other professors.
Originally Posted by PobodysNerfect
Originally Posted by Mahmoud
Another potential problem area is product loads. If we use the actual specific heats, latent heats, etc. to determine the cooling loads, we can be short of capacity, if the owner decides to use a different product at a later date.
A safer method is use to the specific and latent heat of water to determine the product cooling loads. The owner can use anything, and the system will still work. This does make the system larger, but with this method it is more flexible and adaptable to changes.
Some thoughts for your review....
Regards,
US Iceman
20-09-2005, 02:57 PM #12
100 % agree with you US Iceman about the teaching methods
20-09-2005, 05:02 PM #13
Institue of Refrigeration does a very good cold store design guide book. Used it for our apprentice scheme some years back.
www.ior.org.uk
There used to be good Searle guide from the old days 1980 ish (IP Units only) may have a copy in the attic. Will have a look if your interested.
DerekDerek
20-09-2005, 09:05 PM #14
I'll check it , thanks Derek
20-09-2005, 09:32 PM #15
Originally Posted by botrous
Cerche sur ASHRAE, refrigeration, HVAC,...It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
20-09-2005, 09:45 PM #16
Veut-tu m'envoyer une copie svp? J'ai aussi trouvé via Bearshare (P2P) quelques logiciels qui peuvent être intéressant pour vous
Pour le logiciel P2P Bearshare qu'on a parlé l'autre fois , je l'ai installé sur mon ordinateur mais il a fait des problemes donc je l'ai relevé , sa serait interessant si tu peut m'envoyer ces logiciel que tu juges interessant pour moi . . .
Et merci beaucoup d'avance
SalutationEngineering, sciences, math, physics and my brain will generate "not responding " soon
Onion and potato ammonia cold store
By Josip in forum IndustrialReplies: 24Last Post: 13-09-2010, 11:39 AM -
cold river water
By eftimios in forum FundamentalsReplies: 8Last Post: 09-11-2008, 07:37 PM -
expansion valve aint cold
By justinworne in forum Trouble ShootingReplies: 6Last Post: 26-07-2006, 10:52 PM -
Installation of cold room
By Josip in forum Legal-Business-MarketingReplies: 12Last Post: 12-03-2006, 10:20 PM -
Low Temperature Cold Store
By iceman007 in forum CommercialReplies: 12Last Post: 17-11-2005, 12:23 AM
