Results 1 to 19 of 19
    May 2006
    Isle of Wight, Uk
    47
    424
    Diamond core drill
    Can anybody recommend a 240v diamond core drill? I've knackered another one. I hired a makita 8406 the other day, seemed quite good, and very compact and light.
    For years I was using a bosch multidrill, took loads of abuse but clutch gave up, should have scrapped it long before. The one I've just ruined was made by a company called freud, it was a proper diamond core drill, but it only lasted a couple of years if that.
    What do the rest of you use?
    Andy
    3,853
    Re: Diamond core drill
    We've got a makita one, proper diamond drill one, had to get the clutch replaced in it after we had a labourer 'helping' on a big job, but it must be four or five years old now and still going.
    I did fancy getting a hilti one but it wouldn't get enough use really. One thing with the main brands is you can get them fixed rather than replacing them.
    Jon :-)
    Jun 2009
    Lusk , Dublin
    1,115
    For me it's Hilti all the way !
    There is no substitute .Was never a fan one for all tool's.
    Buy the right tool for the job and only use it for it's intended purpose.
    I'm sure opinions will vary .
    The Hilti stuff is expensive but in this case you get what you pay for.Ebay's always worth a look.
    If the Makita is more your cuppa have a look here.
    http://www.lawson-his.co.uk/scripts/...ing%20Machines
    Happy shopping.
    Stu
    Tool's ? check ! Condom's ? check !
    Oct 2007
    manchester
    5,639
    45
    hilti te16m good for up to 100mm cores,all hilti stuff has a free service with 2 yr warranty.the more fixings u buy when u buy hilti stuff the drill gets cheaper.
    Sep 2003
    ISRAEL
    72
    4,248
    Hilti by far.
    The best electric tool aver made.
    Got the TE55 for large holes [ up to 100 in concrete] and the TE6 for small jobs.
    They are the cheapest cause they last for ever and no need to repair.
    Aug 2008
    Baltics
    786
    Which brands' dry diamond cores do you use to cut (moderately) reinforced concrete?
    Oct 2007
    manchester
    5,639
    45
    marcrist core bits-i dont bother with the water cooling fittings-too messy!
    Aug 2008
    Baltics
    786
    Hello
    I agree, however, dry cutting is dusty in its turn.
    I am interesed in dry cutting not big diameter holes in concrete, some 2" may be. An alternative (more unsightly, however) to the coreing is a demolishen hammer, masonry bit, and a rebar cuter. What to chose I don't know.
    Oct 2007
    manchester
    5,639
    45
    core cutting dry -just put a hoover nozzle and all the dust goes-a good cre cutter can cut through 10mm rebar-it does take time-dont have the drill on hammer or youll smash the teeth-put a 10mm pilot hole through and then keep the pilot bit in to save you going off course if it is a thick wall
    Dec 2010
    Toronto, Canada
    1,454
    I have been using my Bosch for 15 years and doing up to 6" dry cores with it. Before that I had an AEG but I havent seen them for years around here. Watch out for the chinese bits as I have seen them die a horrible death pretty quickly.
    As much as I like Hilti and i do have a TE5 and TE15, the repair costs are nuts.
    Mike
    Aug 2008
    Baltics
    786
    You meant Marcrist cutter?
    Just found Kern in Europe seems to make good wet cores.
    Have not found yet however no producer who would claim their cores cut rebarred concrete dry.
    Oct 2007
    manchester
    5,639
    45
    i meant to put core cutter-no one claims to cut rebar-but trust me ive done 450mm deep holes 75mm thick with extension bars and gone through loads of steel rebar upto 10mm thick-it does slow the cutting down but does the trick
    Aug 2008
    Baltics
    786
    Thank you, then I'll probably be looking for these cores.
    Jan 2009
    Canary Islands
    74
    144
    Hi all.
    Just seen this thread. We have been using a DeWalt core cutter for the past three years, and the only problem we've had was caused by a voltage spike which took out the voltage stabilizer and ultimately the motor.
    Our normal sizes are 52 and 65mm, and even using relatively cheap diamond core drills, will go through reinforced concrete and rebars. The trick is not to expose the steel (you'll rip the teeth off), but leave it embedded in the concrete, and take it slowly.
    Now in the process of buying some core drills from a company in Stoke. We'll see what they're like when they arrive!
    Best regards, Graham
    en boca cerrada no entran moscas
    Aug 2008
    Baltics
    786
    Sorry, I did not understand, you do not cut the rebar (but bent it aside)?
    Have someone tried using a powerfull sds + drill and a water swivel instead of a diamond core drill machine ?
    Dec 2010
    ZA
    154
    He is talking of cutting through both the concrete and the steel together. If you remove the concrete then the core bit will bind and break when it hits the steel and is only cutting on a point, not across the whole circumference of the bit.
    Must admit I tend to hire the larger coring tools, as I do not often have to do more than a 50mm or 60mm hole through concrete. I go and hire a big Hilti machine, they generally will do almost any hole, the last time I nicked a 25mm rebar at the edge of the hole, but luckily did not cut through it all the way, just polished it a little.
    For my holes I use a cheap Makita dry core bit, and a Bosch SDS drill to drive it. Just let it run with no force, the drill is very good at getting it to core, with no need to apply more than the minimum of force to keep the bit at the bottom of the hole. If you do a King Kong then the drill will last 5 minutes. Mostly I use it to do brick, and with block it often cuts so fast I almost feel like I am going to go through the hole as well with it.
    Aug 2008
    Baltics
    786
    Thanks for the explanation, SeanB
    You can buy an adapter with a water swivel for your drill and start using the Bosch as a wet core drilling machine. It goes better with water, and, no need to spend quite a sum for a wet core drill.
    Dec 2010
    ZA
    154
    I had Churchills ( rent a hole) in a while ago to drill a 110 hole for plumbing. Turned out the guys who did that raised floor had filled it partly with rubble and then made the top screed. When the thinwall core bit hit a particularly large piece that was able to move it did a spectacular job of making a core sleeve a collection of metal shards, most in the hole. Took an extra hour to get the core and the remains of the bit out, and to continue to the other side. Luckily the operator was using a very worn bit, he started the second part with a brand new one.
  19. #19
    Nov 2011
    india
    35
    13
    Hi..
    I too use makita 8406..It is the proper diamond core drill according to me..And i am extremely fine with that..It is very light and compact too..
