Thread: questions
    Oct 2009
    merida mexico
    54
    282
    15
    questions
    how many cfm per ton of refrigeration?
    which is the optimum speed of the water to a heat exchanger?
    thanksssss
    Mar 2011
    Singapore
    212
    Re: questions
    AHUs might calculate 400 cfm per RT.
    But Packaged and DX, VRF, VRV you can't do this, they are pretty low 300 cfm to 340cfm per RT.
    Optimum speed is based on heat Exchanger size and pipe size I guessed. What I know is around 5 to 6 CMH or 2.0 l/s minimum flow rate. Speed wise..(Not so sure anyway)
    Oct 2009
    merida mexico
    54
    282
    15
    Re: questions
    heat exchanger alfa laval plate is used to condensr
