Results 1 to 10 of 10
23-03-2011, 10:27 AM #1
Temp probe via wireless to controller - how?
Hi everyone,
I have an application where the distance required between my temperature measurement point & the controller is in excess of 20m. A proposal is to connect the temp sensor (PTC at present - could also be NTC at times), to a wireless transmitter. The controller is then connected to a wireless receiver & the control linkage made.
I've looked at the Carel range of wireless sensors, transmitters, but their local technical support seems to be lost on offering a simple solution.
Are there simple ways of doing this? If so, I'd be incredibly grateful for links & applied wisdom.Engineering Specialist - Cuprobraze, Nocolok, CD Technology
23-03-2011, 09:05 PM #2
Re: Temp probe via wireless to controller - how?
Found this, might help
http://www.processingtalk.com/news/jum/jum147.htmlBrian - Newton Abbot, Devon, UK
30-03-2011, 08:22 AM #3
Thanks so much Brian. A very interesting link. Much obliged.
23-03-2011, 11:22 PM #4
Hi DesA,
sounds like an expensive option, PTC and NTC sensor cables can be strung out up to 200metres with CAT ??? what ever cable and source grounding.
magoo
30-03-2011, 08:23 AM #5
Thanks Magoo. Applied wisdom, as always. This would be my comparative technical position.
I'm just stretching the envelope a little.Engineering Specialist - Cuprobraze, Nocolok, CD Technology
24-03-2011, 08:25 AM #6
Hi desA
Have you checked out the other controller options like Emerson and Dixel? I am pretty sure Dixel have a wireless range. I know the big companies (Distech and the like) have a huge range of wireless sensors but most only become economical after 10 or so sensors. After all it is only a simple transmitter at one end and receiver at the other (radio). I have been searching lately for phone wireless for my laptop and the prices are ranging from $10 to $550 which just goes to show how much some of these hardware supplies are making.
There was a **** (wow I almost can't believe that they filtered a real name that sounds like rick and starts with D)[did you mean Dick] Smith wireless thermostat available ten years ago for $40 but has not been available for 7 years. It is sometimes quite daunting to search for 4 hours on the net for a real price on such a simple part. But we must persevere to keep abreast with this fast changing technology. Please let us all know what you use on this application.Last edited by Brian_UK; 24-03-2011 at 10:27 PM. Reason: Censored word
30-03-2011, 08:26 AM #7
Thanks so much, Tesla. I'll definitely feed back once things become clear.
So far, Carel SA seem to have hit a complete technology blank. They cannot support wireless for a control signal - I'm advised.Engineering Specialist - Cuprobraze, Nocolok, CD Technology
25-03-2011, 10:19 AM #8
Speaking of PT sensors, do you know of a reasonably priced potted PT1000 sensor that will measure up to 160c? The ones I get are in a 5mm tube but I get them with solar controllers for about 10euro ea and I would like to get them separately. I can run 100m easily.
Des, would this work for you or is it not feasible to run the wire? Do you need matched pairs?
30-03-2011, 06:46 PM #9
Hi Des,
I have attended an interesting day with the people of Dixell from italy.
They have the technology you are looking for.
Please contact them at www.dixell.it
01-04-2011, 10:23 AM #10
