Results 1 to 2 of 2
    fridgeair's Avatar
    fridgeair Guest
    bitzer oil pumpl filter
    how do i replace oil filter on bitzer compressor oil pump.
    having problem with oil on comps replaced inline oil filter but want to replace oil filter on pumps.
    where is filter located on pump?
    thanks in advance
    Feb 2009
    Australia
    272
    Re: bitzer oil pumpl filter
    fridgair,
    There is a strainer on the lower right of the comp when looking at the oil pump end.You will need to drop the pressure first of course and then the oil and then remove the strainer.The strainer will usually be covered in sludge.
    Lawrie
    Remember we are here for a good time, not a long time.
    Trust me i'm a Fridgy.
