    Nickolaos's Avatar
    Nickolaos Guest
    Signle Stage Questions
    Hello, i am relatively new to subzero cooling. I have a little devil evaporator, 1hp condenser and an aspera 1/8 hp. I tried two times make it work, using r404a,but i failed. Can anyone help me fix it please?
    70
    10,625
    52
    Re: Signle Stage Questions
    It would seem that you need to do some reading and finding a friend with the same interest.
    We cannot see your system from here and without any fact or figures your request is impossible to answer.
    Nickolaos's Avatar
    Nickolaos Guest
    What exactly would you like to know. I have pictures, and pressures, which were wrong, and thats why it didnt work i think.
    70
    10,625
    52
    OK,
    What are the pressures/temperatures
    Sub-cooling, superheat
    If you don't supply the information we are not going to spend time dragging it out of you bit by bit.
    Mar 2011
    Canada
    26
    What did failed... ? Be more precise if you seek answer.
    Nickolaos's Avatar
    Nickolaos Guest
    Subcooling it had about 1 bar, superheat around 6.7 bar. Reading more about single stages and asking i think that superheat preasure should be about 200psi on load.
    Oct 2006
    1,848
    15
    Quote Originally Posted by Nickolaos View Post
    Hello Nickolaos.
    You have all the descriptions wrong mate.
    It is either a lanuage thing or you don't quite understand
    what is being asked of you.
    We need to know specific pressures and temps throughout the
    system to have any sort of idea.
    I'll give you the benifit of the doubt and put it down to language.
    So you need to give us
    Suction pressures
    Discharge pressures
    Temp of suction pipe from the evaporator
    Temp of liquid pipe from condenser
    Then we need
    Air onto and off of the evap and Condenser.
    Then we need to know what you are cooling and what type of environment
    it is in.
    Extra things like is it cappilary, TEV, Temp range and other things like that.
    If you give us all the information we might be able to talk about
    things, but untill then we are just guessing.
    taz
