Results 1 to 13 of 13
    Apr 2001
    2,099
    27
    Le Unite Silensys Condensing Unit
    I am specifying these units for an installation many miles away
    I am wondering if any member has experience of these and what the experience is like.
    Do they come factory fitted with sight glass, drier, etc also possible pre charged??
    Apr 2001
    2,099
    27
    Re: Le Unite Silensys Condensing Unit
    Also
    Are the floor mounted or can they be bolted against the wall
    Sep 2003
    ISRAEL
    72
    4,248
    Hi Abe,
    These condensing units, comes with a short tube from the suction valve and from the liquid receiver is your business/
    You can mount it to the wall, but remember the weight.
    Chemi
    Oct 2003
    5,630
    34
    We already installed several units: there is a filter-dryer and sight glass which can be seen through a hole in the casing (i think soldered), a power relay, a fuse, a safety power switch outside the unit, A HP/Lp safety cut out, proportional fan speedregulation, LP and HP service valve on the outside, predrileld brackets underneath teh unit and additional 2 brackets which can be bolted to those underneath the unit so that it can be attached to the wall, insulated inside around the compressor, ...
    They're realy silent but expensive.
    Sep 2003
    ISRAEL
    72
    4,248
    So how come, they dont come with all the extra's over here?
    Chemi
    Oct 2003
    5,630
    34
    Just googled a little bit
    Schematics (in Norsk or Danish or something similar..)
    http://www.modkjol.no/wh/mk/MKDokume.nsf/43f94b7c487bea46c125690c0041418d/6f90a40d3c7515cbc1256df8004ed60b/$FILE/SilensysDel2.pdf
    Aiyub, Chemi have a look at www.tecumseh-europe.fr and click left below on the Silensys units and you will get a nice movie how to install the unit and see what's inside the unit.
    Oct 2004
    Scotland
    1,454
    21
    We have used those units many times. They seem to be of good quality, nice plasti coating covering strong metal casing. Even the service cover is quite heavy and solid. Good overall units.
    and go get a cuppa
    May 2005
    manchester
    49
    48
    we have installed many of these condensing units for multi deck dairys.
    2.5mtr nimes and alva maxi found these unit good no major problems.
    fairly basic condensing units easy to work with all round.
    also we use j e halls also not to bad found few with leaky reciever at the fused plug watch out for this if you ever use these.
    the silensys doesnt come pre charged flared suction and liquid.
    j e halls braized suction and liquid also not pre charged.
    Aug 2005
    manchester
    47
    These units are great, but check the size of the receiver before intallation. Especailly for pump down jobs. Some units have really small receivers. But they are great units on the whole.
    :eek:
    Aug 2005
    Australia
    42
    44
    Cant believe how quiet these units are!!!! Have used some new units by emerson, come with copeland scroll installed, reciever, drier, sightglass, hp/lp, contactor, fan speed control pretty much everything to go, all you have to do is connect mains power and vac and charge, reciever size looks a bit small though.....
    flip1's Avatar
    flip1 Guest
    I'm not a refridgination engineer, but i have just have one of these units(Silensys by Tecumseh) fitted below my window to chill the stock in the off-licence below my flat. It looks like they are a very quiet machine in the industry, but it's still disturbing 6ft from your bedroom window! Does anyone know if you can get any attenuation for them. It's also noisy when it turns on and off intermitently. Any help would be appriciated as i really am loosing sleep because of it!
    Phil
    Feb 2006
    derbyshire
    610
    there a good unit with a low noise rating, siting it just beneath a window is looking for trouble even if there is no where else to put it, either ask the landlord to move it or call in the shop just before they close and buy a case of strong lager.
    Oct 2006
    Bucks, U.K.
    71
    604
    Can confirm they are well built and silent running. I had a query on wiring diagram re crankcase heater...diagram was wrong ... unit was wired correctly. Flared valve connections. Units have N2 holding charge. Believe foot mounts convert to wall mounts.
  1. M I T S U S H I T A ac unit with no condensing unit
    By Chinua in forum Air Conditioning
    Last Post: 28-07-2006, 06:54 PM
  2. York/Bristol Condensing Unit
    By Abe in forum Commercial
    Last Post: 03-02-2003, 07:46 PM
  3. Matching Evaporator with Condensing Unit
    By Abe in forum Technical Discussions
    Last Post: 25-07-2001, 08:57 AM
