    Jun 2010
    Oregon
    superheat and subcooling
    hello folks! I have a question.
    whats the best and surest way to check and adjust the superheat and subcooling on domestic refrigerators and freezers useing cap. tubes. at what pionts do you take the readings? Love this forum, good advice here. Thanks.
    Harvey.
    11,024
    Re: superheat and subcooling
    As most domestic refrigerators are not fitted with access ports I would think the question is hard to answer.
    If they have got access then it is the same as any refrigeration circuit.
    Dec 2009
    South Africa
    45
    28
    Don't need to know that fancy stuff in domestic fridges. As Brain said their is no ports on the high side. Just charge gas according to the weight it needs. Then monitor to see if frost don't form on the suction to close to comp. Most cases you can figured out if it works by touch feeling the heat on the discharge and the cold on the suction. Hope this help.
    Aug 2011
    Australia
    36
    8
    If there is a Back pressure access port on the compressor you can charge in 100 grams of refrigerant the adjust until you have 15KPA of back pressure.
    Hope this helps
    Apr 2006
    55
    1,908
    30
    Quote Originally Posted by Tankerbox View Post
    Harvey.
    Evening Tanker Box
    As everyone previous has said "you have no adjustment" as such
    If it's charged & working, all that needs doing is keep the condensor clean & defost it reguarly
    If charging you have some minimal control
    I charge about 50grams, then just 10grams at a time letting it settle in between, untill its cooling
    Then I let the fridge & freezer pull down to near temp & then open the doors slightly & continue 10grams at a time untill I have 10-8 degree's C of superheat
    Very easy to overcharge & sometimes have to decant & start again
    Note: I never use line valves that puncture the tubework to charge (they will leak adventually) other than to decant a system, always sweat in a schreider fitting
    R's chillerman
    If the World did not Suck, We would all fall off !
