    od1_cu3nc0's Avatar
    od1_cu3nc0 Guest
    a little help in calculating for sensible heat load from solar radiation...
    i'm having a tough time finding the value of absorption, reflectance and transmittance for a tinted glass, does anybody know the exact values? i can't find it on the net, it just says that tinted glass absorbs about 40% heat from solar radiation.. is that right? need help please.. i'm currently designing a centralized 3-story office building with E/W orientation, and all the glasses we're tinted.. please help.. thanks
    Oct 2001
    Nottingham UK
    5,668
    Re: a little help in calculating for sensible heat load from solar radiation...
    od1_cu3nc0's Avatar
    od1_cu3nc0 Guest
    thank you so much!!
    Jan 2006
    Croatia
    68
    2,261
    31
