    Aug 2005
    iraq
    67
    130
    chilled water pump design
    compliments
    any body know the basic equation for desiding the flow rate of the chilled water pump with respect of the size of evaporator in tons
    thanks
    Sep 2004
    Dubai - United Arab Emirates
    44
    Re: chilled water pump design
    Dear Afif,,
    afif the flow rate of a chilled water system is related to the tonnage, first you have to transform the tonnage to KW, i.e. 1 Ton = 3.41 KW, then you can apply this formula:
    Q= m x Cp x DT
    Q: Capaciy in KW
    m: Flow rate (Kg/sec)
    Cp: Specific Heat (For Water 4.18 KW/Kg.K)
    Dt: Delta T (entering - leaving chiller water temp)
    then u'll get your flow rate man ..
    Oct 2003
    5,630
    Jun 2005
    Madison
    61
    32
    Quote Originally Posted by Mahmoud
    Dear Afif,,
    Q= m x Cp x DT
    Q: Capaciy in KW
    1 ton = 12000 Btu/hr = 3.5168528421 KW
    5,667
    Specific heat of water = 4.19kj/kg.K
    kj/s = kw
    Dec 2004
    LEBANON
    44
    854
    Hi guys
    Afeef take care man , if you are using glycol or other antifreezing agent the specific heat of the blend changes .
    Best regards
  1. pure water from air
    Last Post: 26-02-2009, 12:25 PM
  2. Homemade Heat pump water heater
    By busman in forum Technical Discussions
    Last Post: 05-02-2008, 04:04 PM
  3. VFD heat pump water heater?
    By star882 in forum New Technologies
    Last Post: 23-05-2006, 08:36 PM
  4. Building a wine cabinet
    By Rory in forum Technical Discussions
    Last Post: 13-07-2004, 08:28 PM
  5. chilled water PHE
    By priti in forum Trouble Shooting
    Last Post: 31-07-2002, 08:25 PM
