Results 1 to 8 of 8
    pob_1976's Avatar
    pob_1976 Guest
    Undercounter Freezer Not Freezing
    Hi, I have an undercounter freezer that turns the thermostat on for 30 seconds and off for 30 seconds. The fast freeze function has no affect. Could this be the thermostat? Hope someone can help, cheers regards Paul.
    Jun 2009
    Greece
    56
    Re: Undercounter Freezer Not Freezing
    if the freezer is jammed somewhere and it cant breath and has a condenser with fan the condenser might be clogged or mesure the amps on the compressor the windings might be shot and tripping on the overload and not the thermostat if it has a capacitor maybe that needs replacing. but if the fast freeze butn has no effect its most likely the compressor if you can save it do it if not replace it.
    pob_1976's Avatar
    pob_1976 Guest
    Thanks Tony for your reply, regards Paul.
    Apr 2001
    79
    5,071
    35
    An overload would stay off longer. I'm thinking low pressure control.
    Jun 2009
    Greece
    56
    come to think of it normaly if its a houshold freezer the compressor wouldnt start after a 30sec. run unless the valves are shot in any case you would still need a compressor change.
    Oct 2007
    manchester
    5,639
    45
    compressor is siezing-not yet siezed hence ur getting 30 seconds of running then the klixon will reset after 20-30 seconds. household freezers dont have pressure switches
    Dec 2009
    South Africa
    45
    28
    You sure it is running and not humming.
    Nov 2006
    708
    23
    Possibly a ptc relay failure (danfoss) they do this sometimes
