    495
    Howden wrv screw compressor
    Hi guys i,ve been asked to inspect thrust bearings and change shaft seal ,and i don,t know what thread and the length of jacking bolts are and seal puller threads on howden wrv screws and i be greatful for any info , i have the manual but not the tool kit sizes or threads, thankyou
    Croatia
    68
    2,263
    Re: Howden wrv screw compressor
    Hi, Ghaz
    Quote Originally Posted by GHAZ View Post
    Which type of WRV is in question? Sounds like 163 size? Which manual you have?
    Best regards, Josip
    Ghaz,
    If you have a manual the thread sizes should be in torque table for each bolt size & its location.
    The newer machines are a mix of metric & imperial , so its a guessing game.
    What vintage is it ?
    495
    its a 204 the manual i have is an installation one with thrust settings
    Ghaz,
    Newer compressors as follows
    1 metre lenths of 6,8,10,12,16 mm threaded rod with approx 6 nuts , washers.
    Thrust bearings inner races secured by plate & 3 bolts
    Thrust housing gland plate secured by 3 bolts & locking wire.
    Pay particular attention to torque settingas it must be correct.
    Older compressors
    Same as above but 1/4 ,5/16/,3/8", 1/2", 5/8 UNC
    Thrust bearings inner races secured by locknut & washer
    495
    Thankyou Ranger1
