Thread: Hot Gas
    Oct 2010
    Israel
    5
    Hot Gas
    Hi there,
    Does anybody know if there is a hot gas flow control valve, controlled with a step motor?
    The valve should have minimum pressure drop at 10-40 Bar range.
    I know about Sporlan & Siemens hot gas bypass valves,is there anything else?
    Sep 2003
    ISRAEL
    72
    4,248
    Re: Hot Gas
    Step motor can be fitted on many kind of valves.
    Why do you want to control the hot gas? What's your application?
    Sep 2009
    Iran
    66
    672
    1
    Re: Hot Gas
    valve should be spindle type to control flow.
    Jul 2010
    manchester
    212
    15
    Re: Hot Gas
    i think carel do these types of valves i think i may of seen them on there site whilst looking at drivers for there EEVs
    your only as good as your last job
    Jan 2006
    Norway
    1,035
    4
    31
    Re: Hot Gas
    How about a danfoss ICM valve with a ICAD regulator it will give you step-less regulation for better accuracy
    -Cheers-
    Tycho
