    Aug 2009
    Iran
    33
    12
    capacity control in reciprocating compressors
    Which system of capacity control in reciprocating compressors is more reliable?
    1.- Hydraulically controlled variable-volume clearance pocket
    2.-Stepless capacity control system that uses finger-type unloaders pneumatically actuated. The system unloads the valve for only a portion of its stroke.
    Does anybody have experience with any or both systems?
    It seems that the second system could have problems of leakage by the shaft of the unloader.
    What are the benefits and the problems of each system?
    Thanks a lot
    Somerset
    69
    4,698
    Re: capacity control in reciprocating compressors
    I cannot think of a recip with type 2 described. (Never ever heard of a pneumatic system before?)
    Could you suggest what comps have such a system.
    Aug 2009
    Iran
    33
    12
    the Peter Brotherhood comps.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Dresser Rand, as it is called now, does not produce refrigeration compressors.
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi, Rahju
    Quote Originally Posted by Rahju View Post
    Thanks a lot
    Seems you are using those compressors for process gases like nitrogen (air), LNG or similar and probably they are oil free compressors which we are not using in refrigeration except Danfoss Turbocor centrifugal compressor ...
    Sorry cannot help...
    Best regards, Josip
    Aug 2009
    Iran
    33
    12
    It is true,This compressor is used to compress hydrogen.
    Thanks a lot for your kind answer,Josip.
    May 2006
    India
    74
    399
    Frequency drive could be a solution ............... How will u signal the compressor to lower the speed , a feedback device such as pressure transducer would be required . Compressor not part of refrigeration system hence further expertise will be needed from compressor manufacturer
  1. Compressors - screw or reciprocating?
    By Josip in forum Industrial Compressors
    Last Post: 27-01-2009, 10:36 PM
  2. Frick Quantum LX Compressor control panel: Capacity Control Screen
    By screw_geek in forum Industrial Compressors
    Last Post: 15-06-2008, 06:47 AM
  3. Valve Reed of Reciprocating Compressors
    By Samarjit Sen in forum Industrial Compressors
    Last Post: 18-03-2008, 02:26 AM
  4. reciprocating compressors vs screw, for NH3
    By lraja in forum Industrial
    Last Post: 04-03-2007, 02:30 AM
  5. Overhauls on Reciprocating compressors on packs
    By Mark in forum Supermarket Refrigeration
    Last Post: 14-03-2004, 02:04 PM
Tags for this Thread
