Results 1 to 11 of 11
    maxtan's Avatar
    maxtan Guest
    Smile Two small or one big screw comprossor should I take for ice making?
    Hello
    I would like to thank every one here on this forum for the informative threads which helped me to learn a lot while I don't have an idea about the refrigeration.
    Actually I am working in an ice factory in KSA .We are going to buy a new block ice .However we have two offers and I don't know which one is better ?:
    2X HSK7461-80 Semi-hermetic screw compressor
    or
    1X HSN8571-125 Semi-hermetic screw compressor
    I have a questions ,,please help
    How to know how many horse power do they have ?
    sorry for my English :\
    Best regards
    Max Tan
    495
    21
    Re: Two small or one big screw comprossor should I take for ice making?
    The 2 compressors each have 80hp and the single compressor has 125hp, you be better with 2 compressors because if 1 breaks down you still have the back up
    Dec 2008
    Bucharest
    44
    Hello .
    I recomanded 2 screw compressors .Like Ghaz ,you will have 1 compressor for back-up and a better capacity control on the system.
    I recomanded with 2 refrigerant circuits .
    Best regards.
    Nov 2004
    China
    176
    Get an offer for a real plant using ammonia. it's more economical and better for the environment. In 6 years in KSA I installed only ammonia plants and scrapped only ***** plants.
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi, charlie n
    Quote Originally Posted by charlie n View Post
    ... must say agree with you 100% .....
    Best regards, Josip
    Aug 2007
    Adelaide Australia
    70
    562
    Hi maxtan
    I would agree with charlie n, ammonia would be better one of the most efficient refrigerants around.
    Two comps are the best option for the reasons given by GHAZ and bayculaudyu but this option would cost more because you will have to double up on controls, more pipe work, etc.
    If there are no finincial constraints I would go for ammonia with two comps as it is always good to have a back up compressor.
    Paul
    maxtan's Avatar
    maxtan Guest
    Thank you everybody for the suggestion
    I know that the amonnia is the most efficient option. However, we didn't choose it because of safety purpose. It's quite dangerous and we don't want to sacrifice our workers .
    I have heard about some cases of ammonia infiltrations it's deadly :S
    Thanks again
    Max
    May 2006
    canada
    ammonia is dangrous , yet it is the most efficient gas, compare being hit by a bullet in the leg or be exposed to nukes !
    I definetly agree with the gentlemen on 2 circuits and two compressors in HVACR two separate circuits are safe !
    Nov 2004
    China
    176
    Ammonia is only dangerous if not handled properly. compared to putting money in the bank or burning it in a wasteful design I always choose ammonia. Any professional will do the same.
    Auckland
    74
    3,357
    37
    Go for 3 screws with 50 % redundancy, which means you can have one screw off line for maintenance, plus extends the life of each machine as lead lag is rotated. Ammonia is the best, and should not be a problem if designed and installed and commissioned correctly, add maintenance as well
    Apr 2009
    South Africa
    49
    108
    I would go for two screws each being 125 hp so that i have a 100% back up and time for maintenance on each comp. I would also go for ammonia as it is much cheaper in the long run.
    We have massive ice plants producing +- 200 tons of ice in 24 hrs and its all ammonia.
    THE BEST WAY OF LEARNING IS TO DO IT YOURSELF!!!
  1. Replies: 4
    Last Post: 26-07-2010, 09:08 AM
  2. do u have any data on comparison of single screw and twin screw?
    By vuputuri in forum Technical Speculations
    Last Post: 22-02-2008, 03:52 PM
  3. ice making
    By llewelyn in forum Commercial
    Last Post: 06-05-2007, 10:49 PM
  4. ice making
    By llewelyn in forum Fundamentals
    Last Post: 01-05-2007, 02:33 PM
  5. Ice Making
    By Abe in forum Legal-Business-Marketing
    Last Post: 20-03-2002, 08:53 PM
