Thread: danfoss shut off valve
24-02-2011, 09:35 PM #1
hi chaps looking for some help please, working on a pack today with no model numberfound the discharge shut off valve leaking its a danfoss 1 3/8" valve like the Henry type with the valve stem at about 60 degrees i want a repair kit for it but carnt find the model number and carnt find it in the danfoss catalog or the 2000 book of instructions the valve is in a silly place and don't really want to cut it out! i am lazy!!!!!!!!!!!!
cheers boys
24-02-2011, 10:23 PM #2
Re: danfoss shut off valve
I think what you're after is in this ,I also think you're valve is an SVA-ST 65.
But i'm only guessing.
-Cheers-
Tycho
24-02-2011, 11:38 PM #4
hi chaps its a brass valve system on r404a
24-02-2011, 11:44 PM #5
hi found it, its a gvc35s, thanks for the help
24-02-2011, 11:53 PM #6
Is it the same as the one listed on pages 45-46 of this catalog ?-
http://www.erawanrefrigeration.co.th...y/Rk0yr102.pdf
The spare parts kit no.s are also listed..
25-02-2011, 04:46 PM #7
I could have sworn I put an attachment with the previous post
Here's on that might be useful to some one
http://content.yudu.com/Library/A1n1...ources/287.htm
Looks like I was wrong anyway
My bad !
StuLast edited by stufus; 25-02-2011 at 04:50 PM.
Danfoss Thermostatic Expansion Valve
By fopa in forum Heat PumpsReplies: 0Last Post: 29-01-2011, 12:47 AM -
ICS Danfoss valve
By jax1 in forum NH3Replies: 3Last Post: 29-08-2010, 05:28 PM -
Danfoss WVFX Valve
By Co2_Scientist in forum Trouble ShootingReplies: 1Last Post: 16-10-2009, 11:24 PM -
Danfoss water valve
By glenn1340 in forum IndustrialReplies: 7Last Post: 10-10-2009, 07:01 AM -
Danfoss PHTQ Valve
By dallan in forum IndustrialReplies: 5Last Post: 29-07-2006, 11:25 PM
