    bsballdreamer's Avatar
    bsballdreamer Guest
    Low oil pressure on vilter compressor
    Hey I bought a reconditioned vilter recip and it keeps cutting off on low oil pressure. During the freeze cycle the oil pressure is around 50psi but during the defrost/harvest cycle the oil pressure drops to around 5psi...help please
    Aug 2007
    Sydney
    1,083
    Re: Low oil pressure on vilter compressor
    Hi bsballdreamer
    Could you give us a little more info like model#, what type (components) for oil seperation and return. And what does the comp sight glass look like at 5psi? What stage of loading also. Is there only one compressor and what is it cooling. Super heat would be good too. And any thing else you think might be helpful.
    bsballdreamer Guest
    It is a vilter 456xL. I use it to run a volt ice maker with ammonia. It was low on oil but that poses a different problem...where is my oil going? There is a small amount of oil dripping near my high side shut off valve?
    bsballdreamer Guest
    Got it all straight thanks.
    Sep 2009
    Iran
    66
    672
    1
    during defrost time might you liquid returning to compressor . what is your suction pressure in defrosting time .
    oil cycling in system so you should have enough oil in compressor and all filters should be clean
    tight all nuts at shut off valve
  1. vilter screw vs vilter reciprocating
    By lynark in forum Technical Speculations
    Last Post: 20-10-2010, 10:00 AM
  2. vilter compressor
    By lynark in forum Trouble Shooting
    Last Post: 22-08-2010, 02:11 AM
  3. Vilter compressor unloader valve
    By duke717 in forum NH3
    Last Post: 17-08-2010, 03:06 AM
  4. Vilter HP compressor
    By coolcmt in forum Industrial Compressors
    Last Post: 26-06-2010, 08:47 PM
  5. Compressor with no pressure difference
    By marc5180 in forum Air Conditioning
    Last Post: 17-12-2009, 08:22 AM
