Results 1 to 24 of 24
    gianpierone's Avatar
    gianpierone Guest
    Lightbulb Microchannel condenser, my experience, I ask you your opinion
    Good evening, everybody.
    I always follow this forum with great interest because it's full of competent people, congratulations.
    That is my first post and I am writing to ask you your opinion.
    I am a thermodynamic engineer in an Italian company that produces refrigerated cabinet for supermarket
    Recently I tested a multideck cabinet with built-in unit condensing, the condenser is a microchannel type.
    It 'a very widespread application in the field of large distribution but I don't understand because.
    From the tests I did I found many advantages and no disadvantage
    The charge gas and 'reduced by 30%.
    The temperature of condensation is less than the previous condeser
    The pressure is equalized in less time.
    The size of the condenser are small, only 2 cm thick.
    Better ventilation in the unit condensig compartment.
    Lower cost of manufacture.
    So many benefits, but this application is not common used , why do you think?.
    I apologize in advance for my little English language.
    Mar 2006
    Merate (LC) - Italy
    52
    2,549
    Re: Microchannel condenser, my experience, I ask you your opinion
    Ciao, gianpierone. As in most new products, it takes time from availability to acceptance. As a manufacturer of big chillers, we are using microchannel condensers in sizes up to 6 meters in length and found them to be cheap, reliable and all in all a better alternative to standard Cu/Al condensers.
    The main advantage is that these condensers will no longer rely on copper that is becoming an increasingly expensive commodity.
    We are now testing microchannel water coils (for free cooling).
    Apr 2008
    canada
    75
    94
    B”H
    Gianpierone,
    Who is the manufacture of microchannel coils.
    3,856
    Are these micro channel coils made just out of aluminium?
    How are they joined to copper pipe work?
    Jon
    Mar 2006
    Merate (LC) - Italy
    52
    2,549
    Yes, they are completely made in aluminum. The joint is made with a bolted flange in a gasketed seating
    This is how they look like
    gianpierone Guest
    Hi Michaelm, I have bought condenser microchannel to Val.Mex. in Italy, visit www.valmex.it
    gianpierone Guest
    Hi Monkey , it is possible connecting the microchannel conder with blocks, lokring, nipless, copper pipe (by welding aluminium and copper).
    I have used blocks.
    3,856
    They look similar in design to vehicle air con condensers, if they are as reliable as the ordinary ones then its seems like a good thing.
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Very similar Jon. Excellent heat transferre. The only disadvantage when used in vehicles is when metal from a damaged compressor manages to get caught in tubes, however i think some vehicles have removable strainers now.
    Hi No Nick Name,
    are these evaps flooded design.
    magoo
    Apr 2008
    canada
    75
    94
    Quote Originally Posted by gianpierone View Post
    B"H
    Thank you so much.
    Mar 2006
    Merate (LC) - Italy
    52
    2,549
    Hi No Nick Name,
    magoo
    No, they are not flooded, and they are not evaporating coils.
    Jun 2006
    South Coast
    278
    Carrier and York use microchannel coils on their chillers and are made by a US Company called Delphi
    Dec 2009
    new york
    these delphi coils tend to leak, already replaced about a dozen coils and would like to get a class action suit started
    Dec 2009
    new york
    i mayb a rookie poster but if it quacks like duck, walks like a duck most likely it is a duck, n coil is problem
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Quote Originally Posted by billdozza View Post
    What is causing the condensers to fail? Corrosion or quality problems? Vehicle condensers of this type design take a beating from vibration and the elements for years..Mike.
    Jun 2006
    South Coast
    278
    Hi Billdozza
    Which chillers do you have the coil leaks on.
    Mar 2009
    KZN, South Africa
    63
    2,212
    Automotive-style condensers suffer from a number of major failure modes.
    The most common are:
    1. Galvanic corrosion;
    2. Fatigue/vibration failure.
    Mar 2009
    KZN, South Africa
    63
    2,212
    Galvanic corrosion mechanism:
    The fins are generally clad with aluminium/silicon eutectic material;
    The tube is extruded/formed, with no cladding;
    After brazing, the tube generally tends to become sacrificial relative to the fin material, with consequent failure mode as tube corrosion.
    The fin material can be adapted to move the galvanics around a little & extend corrosion life. This is a juggling act, specific to automotive operation & testing regime.
    Mar 2009
    KZN, South Africa
    63
    2,212
    Development of the next generation of copper-copper condensers is in progress.
    Feb 2009
    Australia
    272
    Has anyone got information/facts on these failures?
    Remember we are here for a good time, not a long time.
    Trust me i'm a Fridgy.
    Dec 2008
    India
    how about danfoss sanhua mchx? any 1 using it?
  23. #23
    Dec 2008
    India
    in india danfoss started selling its mchx , any good alternative of danfoss?
  24. #24
    Feb 2009
    Australia
    272
    billdozza,
    Can you tell us more about the failures of the microchannel condensers please.
    Lawrie
  1. Your Opinion guys, please!
    By gordo_guero in forum Fundamentals
    Last Post: 06-08-2009, 11:46 PM
  2. Differance Of Opinion
    By SIGNSTU in forum Fundamentals
    Last Post: 12-03-2007, 01:41 AM
  3. 2nd opinion please
    By superswill in forum Trouble Shooting
    Last Post: 11-01-2007, 05:47 PM
  4. opinion about compressors
    By Servicefrigo in forum Technical Discussions
    Last Post: 09-03-2005, 05:50 AM
  5. A Europeans opinion
    By shogun7 in forum Chit Chat & Service Stories
    Last Post: 05-03-2004, 01:49 AM
