Thread: Earthwise Purge
18-02-2011, 12:50 PM #1
Earthwise Purge
I have to price converting to a new style regerative purge. I was wondereing if anyone has done this. I was wondering how big of a job this is.
21-02-2011, 01:18 PM #2
Re: Earthwise Purge
Please let us know what make and model is the chiller, what kind of purge does it have (Purge outlet to evaporator or condenser?), where is located (Beside condenser or in the top of condenser?) and what method has for cooling? (Chilled water or condenser water)
Also please let us know which make and model purge you intend to install.
I have retrofit in the past two LCV and one CVHE from old style to purified purge and I can tell you the procedure.
Regards,
CV
23-02-2011, 02:40 AM #3
Re: Earthwise Purge
Thanks for the reply. we are changing a eath wise on a CVHE the new regenerating purge has three lines. I was wondering if the vapour supply and liquid return to the condenser can remain the same size or do we have to up size the liquid return to the condenser to 3/8 . I understand that the regereneration line has to go to the evap.
Thanks.
BTW its a air cooled purge
23-02-2011, 12:42 PM #4
Re: Earthwise Purge
Please check your email.
I have sent you a document which, I believe, answers all of your questions.
If not please let me know.
Regards,
CV
Purge Carbon Regen Temp High
By a4anoop in forum Industrial CompressorsReplies: 0Last Post: 29-10-2010, 06:09 AM -
Argweld purge monitor's sensor failure
By Yuri B. in forum New TechnologiesReplies: 2Last Post: 19-01-2010, 01:42 PM
