17-02-2011, 01:54 PM #1
Carrier chiller 30gxe162385sk error code 302
Hi Friends,
kindly help me to rectify CARRIER CHILLER 30GXE162385SK ERROR CODE 302 urgently.
your quick response would be appreciated.
Regards,
Peter.
17-02-2011, 07:23 PM #2
Re: Carrier chiller 30gxe162385sk error code 302
Can't find a GXE document but have a GX which probably got similar fault codes.
302 = motor sensor.
Document here
http://eto.carrier.com/litterature/c...OL_09_2007.pdfBrian - Newton Abbot, Devon, UK
17-02-2011, 09:44 PM #3
Your model number seems a bit odd is it US or French made chiller as Alarm 302 is different on each chiller
Can you give full model and serial number and date of manufacture.
French model is Compresser Motor Sensor Fault.
US model is No Motor Current.
21-02-2011, 08:31 PM #4
Hi Friends,
Thank you very much for your suggestions, i have managed to sort out problem, there was a problem with sensor.
once again thank you very much.
Daikin error code, H6 Outdoor Compressor motor position detection sensor error
By rafyro in forum Trouble ShootingReplies: 0Last Post: 16-02-2011, 11:38 PM -
Carrier Chiller 30GX Error Code
By sbkvelocity in forum Trouble ShootingReplies: 8Last Post: 07-03-2010, 03:57 AM -
Chiller 30ra021 Carrier fault code 37
By kondzio85 in forum Air ConditioningReplies: 2Last Post: 26-01-2010, 08:25 AM -
Carrier 30HXC375 Chiller Code 57 and 61
By jfb31 in forum Air ConditioningReplies: 3Last Post: 20-09-2009, 09:15 PM -
Carrier Chiller Code 68
By torrman in forum Air ConditioningReplies: 4Last Post: 31-05-2008, 02:47 PM
