16-02-2011, 10:34 PM #1
Daikin error code, H6 Outdoor Compressor motor position detection sensor error
Hello From Virginia, USA.. First time posting here and trying to see if I could get any help/advise.. About a month or so ago my indoor unit shut down for no apparent reason, I started back up and it shut down again with 10 - 15 minutes... I ran the code scanner with the remote an get the H6 code, Outdoor Compressor motor position detection sensor error.. The unit model is RXS18DVJU/FTX18DVJU and it was installed 11/05. Any help is greatly appreciated.
16-02-2011, 11:08 PM #2
Re: Daikin error code, H6 Outdoor Compressor motor position detection sensor error
Try this link for a manual, may not work but work a try.
http://extranet.daikin.co.uk/en/docu...m219-41003.pdfBrian - Newton Abbot, Devon, UK
17-02-2011, 01:34 AM #3
Thanks for the response, but I can't access the site. it requires Login and Password..
17-02-2011, 02:23 AM #4
Brian, Thank you I was able to download the manual through another link... I guess I will need to get an Inverter tester to check this out.
Daikin Fan Motor Problem/Error!!
By Auspolak in forum Air ConditioningReplies: 10Last Post: 18-11-2010, 01:02 AM -
Daikin model ry71luv1 error J2 Outdoor Current sensor malfunction
By pab_gm in forum Trouble ShootingReplies: 3Last Post: 27-09-2010, 08:37 AM -
Daikin L6 error code
By syahidian in forum Air ConditioningReplies: 7Last Post: 22-04-2009, 07:34 PM -
Panasonice error code -H14 - Indoor air sensor
By rguadm in forum Air ConditioningReplies: 3Last Post: 16-12-2008, 04:14 AM -
Daikin Error Code AH, Sky Air + VAM HRV
By Brian_UK in forum Air ConditioningReplies: 12Last Post: 11-04-2008, 11:50 PM
