    rafyro's Avatar
    rafyro Guest
    Daikin error code, H6 Outdoor Compressor motor position detection sensor error
    Hello From Virginia, USA.. First time posting here and trying to see if I could get any help/advise.. About a month or so ago my indoor unit shut down for no apparent reason, I started back up and it shut down again with 10 - 15 minutes... I ran the code scanner with the remote an get the H6 code, Outdoor Compressor motor position detection sensor error.. The unit model is RXS18DVJU/FTX18DVJU and it was installed 11/05. Any help is greatly appreciated.
    11,025
    Re: Daikin error code, H6 Outdoor Compressor motor position detection sensor error
    Try this link for a manual, may not work but work a try.
    http://extranet.daikin.co.uk/en/docu...m219-41003.pdf
    rafyro's Avatar
    rafyro Guest
    Thanks for the response, but I can't access the site. it requires Login and Password..
    rafyro's Avatar
    rafyro Guest
    Brian, Thank you I was able to download the manual through another link... I guess I will need to get an Inverter tester to check this out.
  1. Daikin Fan Motor Problem/Error!!
    By Auspolak in forum Air Conditioning
    Last Post: 18-11-2010, 01:02 AM
  2. Replies: 3
    Last Post: 27-09-2010, 08:37 AM
  3. Daikin L6 error code
    By syahidian in forum Air Conditioning
    Last Post: 22-04-2009, 07:34 PM
  4. Panasonice error code -H14 - Indoor air sensor
    By rguadm in forum Air Conditioning
    Last Post: 16-12-2008, 04:14 AM
  5. Daikin Error Code AH, Sky Air + VAM HRV
    By Brian_UK in forum Air Conditioning
    Last Post: 11-04-2008, 11:50 PM
