Thread: pressure drops
14-02-2011, 07:59 PM #1
pressure drops
Hi all,
as it became so common that i ask some stupid questions here i am once again.
Could anybody tell me is there any recommendation for a refrigerant pressure drop in the condenser and evaporator? What are the common values? I dont need it for a particular project, just for an information and orientation
BR to all
Be careful about reading health books. You may die of a misprint.
08-03-2011, 10:30 AM #2
Re: pressure drops
It depends on the size of the condenser or evaporator.
The smaller the pressure drop, is the better.
Usually it lies in Pascals for smaller condensers/evaporators say around 50000 Pascals for 200 kg/hr.
It will not be in bar or Mpa level. Anything above 0.5 bar is poor design for smaller condensers.
The pressure drop is directly related to design of heat exchanger and mainly due to the losses due to friction and corners/flow path.
09-03-2011, 04:33 PM #3
Re: pressure drops
Pressure drop between 2 points of the pipe depends on the flow rate in it.
09-03-2011, 08:06 PM #4
Re: pressure drops
Hi Astoguro,
Acceptable pressure drops in Condensers 5 to 15 PSI (refrigerant side)
Acceptable pressure drops in evaporators 2.5 to 10 PSI (refrigerant side)
Please note that the pressure drop across finned tube heat exchangers is directly related to the coil circuiting, the mass flow and the number of feeds.
Best regardsEngineering, sciences, math, physics and my brain will generate "not responding " soon
10-03-2011, 06:18 AM #5
Re: pressure drops
Thats little over 1 bar for Cond and 0.5 bar for Evap. I agree.
Thanks for the info.
11-03-2011, 09:14 AM #6
Re: pressure drops
You are welcome
30-03-2011, 04:33 PM #7
Re: pressure drops
Thanks guys...I wondered because i have done some calculations in Solkane for a refrigerant cycle because i needed a capacity of the condenser for one building to preselect the pumps and to see is it really worth of doing the Geothermal energy for cooling ad therefore i needed figures...Thanks
Sump Pressure > Suction Pressure
By schquenz in forum Air ConditioningReplies: 7Last Post: 04-08-2010, 01:37 PM -
high suction pressure and low head pressure
By david ashley in forum Trouble ShootingReplies: 2Last Post: 05-08-2009, 06:26 PM -
Reasons for High Pressure / Low Pressure Trip outs
By majikman in forum Air ConditioningReplies: 19Last Post: 02-02-2007, 08:47 PM -
Thanks god, the copper price drops a little
By chistine in forum Air ConditioningReplies: 1Last Post: 17-11-2006, 08:18 AM -
pressure and temperature drops in R22 evaporator
By fedri in forum RefrigerantsReplies: 7Last Post: 09-07-2006, 03:44 PM
