Results 1 to 8 of 8
Thread: Carrier 30rh090
14-02-2011, 08:17 AM #1
Carrier 30rh090
I need to change the pcb of the B circuit of the unit.They tell me that the pcb needs
programming.Is this something that i can do it in the field?
14-02-2011, 06:28 PM #2
Re: Carrier 30rh090
request it preprogramed from the factory or you will need carrier to download the relevant programmes and software youd be better off getting carrier to install the board
14-02-2011, 06:50 PM #3
Re: Carrier 30rh090
Thanks james for reply.I was asking if i could avoid the preprommaning from carrier and do it myself.
14-02-2011, 08:37 PM #4
Re: Carrier 30rh090
No afraid not, you would need a carrier pc and software which is only available to Carrier
15-02-2011, 03:24 PM #5
Re: Carrier 30rh090
Thanks for the help james.
15-02-2011, 08:46 PM #6
Re: Carrier 30rh090
Where in the world are you Harry i might be able to put you intouch with the correct service branch
16-02-2011, 06:14 PM #7
Re: Carrier 30rh090
Athens..greece.
16-02-2011, 09:22 PM #8
Re: Carrier 30rh090
Here you go http://www.carrier.gr/
carrier 550
By charlie patt in forum TransportReplies: 8Last Post: 01-02-2011, 08:26 AM -
Carrier 39 ed 23
By dogma in forum Air ConditioningReplies: 2Last Post: 03-06-2010, 10:59 AM -
carrier
By dgt in forum Tools and CalculatorsReplies: 3Last Post: 28-12-2009, 05:52 PM -
Carrier VAV
By leegally1983 in forum Trouble ShootingReplies: 1Last Post: 03-06-2008, 12:47 AM -
carrier
By headgasket in forum Technical SpeculationsReplies: 6Last Post: 11-06-2006, 07:34 PM
