Results 1 to 2 of 2
11-02-2011, 02:12 PM #1
Determining BTU load of a cold wall pan
I work for a company making custom serving equipment and have made a cold pan we will use in various sizes that will be built into cafeteria serving lines. The pans are sized to hold 1-through 6-hotel pans, each with a capacity of 12"x20"x6". We are having troubles predicting the BTU requirements for these.
We began using the CalcRite software and our early results with the small sized cold pans proved to be acceptable.
All have 6-turns of 3/8" copper tubing in close contact to the stainless steel pan with a thermal mastic to help increase the heat flow.
Any help with this will be greatly appreciated.
Len
16-02-2011, 11:27 AM #2
Re: Determining BTU load of a cold wall pan
For Coldplates use 110btu per sq ft at +10f sst.
Can't go wrong.
LawrieRemember we are here for a good time, not a long time.
Trust me i'm a Fridgy.
Cold rooms heat load calculation
By rooibos in forum FundamentalsReplies: 13Last Post: 07-01-2011, 11:04 AM -
Heat load for cold store
By Sandro Baptista in forum FundamentalsReplies: 7Last Post: 29-11-2010, 10:32 AM -
wall panel supports - cold stores
By smpsmp45 in forum NH3Replies: 5Last Post: 13-07-2009, 10:14 AM -
Support for the wall panels - cold store with no locks
By smpsmp45 in forum NH3Replies: 1Last Post: 10-07-2008, 09:06 AM -
Cold wall vs. Forced-Air, which is better?
By pezagent in forum Technical DiscussionsReplies: 4Last Post: 23-05-2003, 04:34 AM
