Results 1 to 9 of 9
    Nov 2009
    canada
    45
    64
    9
    Damaged/bent evaporater fins
    Hi Guys,
    So the engineers before me use to whack at the fins with a wooden stick to remove ice from the back of the evaps.I know ,i know bunch of dumbasses.My question is i know you can get "combs" i think they are called to str8en them but is there any thing i can use or make up that will do the job as well ???
    Aug 2007
    Sydney
    45
    1,093
    Re: Damaged/bent evaporater fins
    Hi stanthonycold
    I used to use a pair of long nose pliers when the fins were torn or folded over, I know it's laborious but often the combs would tear further or crease the fins. Then I would have an arsenal of combs (plastic and metalrods) to finish the job. You could try to make one like a small paint brush with thin rods but for the time involved I think it's best to spend the money and buy several different types of fin combs.
    Feb 2011
    44
    10
    Give up replace the evap not worth your time ! or just leave it to be so long as air passes over nothing you can do but replace or live with it ....:-)
    Apr 2009
    8
    "IF" you decide to straighten them out yourself be sure to wear leather gloves or bring a good first-aid kit.
    Dec 2005
    Upper left hand corner of the USA
    58
    199
    13
    Wire brush. Start at the straight fins and work your way towards the damage pushing heavily. Rinse and repeat.
    Nov 2009
    canada
    45
    64
    9
    And you guys are suppose to be professionals ...what a joke . Thanks telsa i will try your idea !
    Nov 2008
    birmingham
    155
    13
    i,m with stanthonycold, really lads a fin comb is cheap enough, no matter how big the evap is.
    Nov 2009
    canada
    45
    64
    9
    Im glad you dont work here ,sounds like your a real money saver ! Your in the wrong profession with that attitude .
    Jun 2009
    Lusk , Dublin
    1,120
    http://www.filterace.com/detail.aspx?ID=1232
    Get yourself one of these, job done
    Stu
    Tool's ? check ! Condom's ? check !
  1. Evaporater icing up.....
    By Scooter29 in forum Fundamentals
    Last Post: 13-02-2011, 08:00 PM
  2. evaporater freeze ups
    By mk98064 in forum Commercial
    Last Post: 01-04-2010, 03:59 AM
  3. evaporater leak
    By jebar in forum Trouble Shooting
    Last Post: 07-04-2009, 03:56 AM
  4. cleaning fins
    By giovanni in forum System Optimization
    Last Post: 10-05-2008, 07:49 AM
  5. gas evaporater fridge efficiency ?
    By R de N in forum Fundamentals
    Last Post: 12-12-2003, 04:56 AM
