Thread: Internal light switch
10-02-2011, 05:51 PM #1
I am not an engineer, but have spoken to one who cannot help. I have a frost free Indesit fridge freezer (6-7 years old). Water is seeping from the internal switch that turns the light on when you open the fridge door. No idea where this is coming from, appliance working fine?
Raizer, Liverpool, UK
10-02-2011, 06:33 PM #2
Re: Internal light switch
Mr,
Reduce the thermostat to minimum and try ,if even water is coming it will be internal thermal insulation break down then it your bad luck , contact a tech and get it refilled with poly- form .
with rgds.
10-02-2011, 07:24 PM #3
Check also the door seal, it may be failing and allowed air in/out of the fridge and causing condensation.
11-02-2011, 01:17 PM #4
13-02-2011, 06:16 PM #5
it is not a costly repair, but first you try!
regds
10-03-2011, 01:40 PM #6
I agree into it.
Fujitsu Inverter flashing red operation light and green timer light. Help!
By rianna in forum Air ConditioningReplies: 1Last Post: 18-02-2010, 02:29 PM -
Scroll internal bypass
By Larry2 in forum Heat PumpsReplies: 27Last Post: 15-05-2009, 09:23 AM -
Fujitsu Internal Fuses?
By sinewave in forum Air ConditioningReplies: 17Last Post: 02-07-2008, 09:48 AM -
internal thermo switch
By philjd26 in forum Trouble ShootingReplies: 12Last Post: 25-06-2007, 08:39 AM -
internal piping
By Jase in forum Air ConditioningReplies: 5Last Post: 01-11-2006, 09:32 PM
