Results 1 to 2 of 2
Thread: Toshiba VRF E28 fault
09-02-2011, 08:28 AM #1
Hi all
Got a problem with a Toshiba VRF it's faulting on E28 which I think is a fault on outdoor slave unit. The outdoor slave unit is flashing P22 -03 Now I know P22 is a fan motor fault but not sure on the 03. Is it short circuit on inverter. I'm not very clued up on VRF. Should I replace the fan motor is there any quick fix to get the master unit running
09-02-2011, 01:51 PM #2
Re: Toshiba VRF E28 fault
I would replace the outdoor fan motor IPD (think thats what its called) PCB
Paul
"KEEP IT COOL"
toshiba E04 fault
By langy in forum Air ConditioningReplies: 2Last Post: 13-09-2010, 01:31 PM -
Toshiba Fault codes
By bernard in forum Air ConditioningReplies: 28Last Post: 03-08-2010, 11:09 AM -
toshiba fault
By bangoman in forum Air ConditioningReplies: 7Last Post: 31-10-2008, 02:23 PM -
toshiba a/c fault codes
By fsfd1 in forum Trouble ShootingReplies: 1Last Post: 30-09-2008, 07:10 PM -
toshiba fault codes
By COOL BOB in forum New to REReplies: 7Last Post: 09-12-2007, 08:18 AM
