Results 1 to 9 of 9
Thread: reverse cycle low ambient
06-09-2005, 09:32 AM #1
Heat pump Air conditioner (reverse cycle 1.5,2 tons)
Just wanted to inquire what additional components are required when ambient is Minus 10 degree Celsius apart from conventional components
Our nose is our personal air-conditioning system: it warms cold air, cools hot air and filters impurities
06-09-2005, 11:23 AM #2
Re: reverse cycle low ambient
Hi Abb.
Most manufactures have an optional heater battery you mount on the air intake side of the outdoor. Does'nt really make a whole lot of sense using heatpump in that sort of ambient. But I have seen them in Russia The units seemed to operate satisfactorly. (Cop is drastically reduced) If you are thinking of installing a number of indoors. Sanyo have a 22kw gas engine heatpump available (2 pipe only) that will give you full Heating capacity down to -20 degrees C without any defrost.
Hope this is helpful
regards
T
06-09-2005, 12:14 PM #3
well question is how can u stop defrost on outdoor at such low ambient n if at all reverse cycle units are used what are its basic components
06-09-2005, 07:05 PM #4
Originally Posted by abbasi
Techguy, a electrical heater installing outside the unit is as stupid - I'm not saying you're stupid - as heating with all the windows open.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
06-09-2005, 07:40 PM #5
and go get a cuppa
06-09-2005, 09:46 PM #6
Abbasi are you trying to design one that would work on -10 degrees ???Engineering, sciences, math, physics and my brain will generate "not responding " soon
07-09-2005, 02:51 AM #7
Hi abb,
For the heat pump air conditioner ,it's usually not used in the area below 0C in which the frost issue will come up. But there are still product called they can run on low ambient temp (-10C),they use electric heater to balance the AC unit performance degradation.Others use VFD compressor to make up with high frequency running,I've installed one in my bedroom but it's not too good. So I think the air source heat pump is not fit in cold area.
rgds
LC
07-09-2005, 08:16 AM #8
Originally Posted by botrous
yup mate we were given an inquiry of such sort but i was not convinced as 2 me u cant control frost on outdoor as such low ambient will make outdoor completely ineffective and i agree with PETER as to me
electric heater for defrostin outdoor dun make any logic
But i wanted 2 have opinion 4om u guys as they say
2 HEADS ARE BETTER THAN ONEOur nose is our personal air-conditioning system: it warms cold air, cools hot air and filters impurities
07-09-2005, 11:41 AM #9
I agree with Peter about the heaters , it's like trying to heat the atmospher . . . and i don't think that such application in -10 degrees is possible . . . but as you said 2 heads are better than one , i say 3 heads are better than 2
Actual air-conditioning operation and its cycle
By narongwit12 in forum Air ConditioningReplies: 6Last Post: 02-02-2011, 11:09 PM -
Evaporative Condenser in reverse cycle
By Friobernal in forum IndustrialReplies: 6Last Post: 16-04-2009, 02:06 PM -
pump down for reverse cycle systems
By abbasi in forum FundamentalsReplies: 4Last Post: 21-04-2006, 06:03 AM -
Thermodynamics
By Prof Sporlan in forum FundamentalsReplies: 10Last Post: 12-03-2004, 01:24 PM -
Ambient and Condensing.
By kfjoe in forum FundamentalsReplies: 9Last Post: 07-02-2004, 04:31 AM
