    Dec 2005
    Cheshire
    264
    Mitsubishi Heavy R407c
    Mitsubishi Heavy R407c 20.0kw ducted indoor with controller RCD-H-S-E.
    Controller set temp has been locked on 23degC - how can I unlock this?
    Also when put on heat mode displays hot keep - anybody know what this means?
    Thanks!
    May 2006
    Isle of Wight, Uk
    47
    424
    Re: Mitsubishi Heavy R407c
    You will have to take the controller apart - undo the screw first! Inside there is a group of dip switches that should be labeled, I cannot remember what ones there are - it has been a long time since I have seen one. There is also a line of jumper wires some of which may have been cut, again can't remember what does what.
    The hot keep is a cold draft prevention thingy.
    Andy
  1. mitsubishi heavy ind fdc200vs
    By stevos in forum Air Conditioning
    Last Post: 20-01-2011, 07:27 PM
  2. mitsubishi electric v mitsubishi heavy ind
    By coolhibby1875 in forum Air Conditioning
    Last Post: 04-09-2009, 01:42 PM
  3. Please Help Mitsubishi Heavy Ind problem
    By simplycooling in forum Air Conditioning
    Last Post: 02-03-2009, 11:18 PM
  4. Mitsubishi Heavy
    By Krondor in forum Air Conditioning
    Last Post: 22-11-2007, 12:31 AM
  5. mitsubishi heavy
    By ric in forum Air Conditioning
    Last Post: 01-09-2006, 11:18 PM
