Results 1 to 2 of 2
Thread: Mitsubishi Heavy R407c
08-02-2011, 01:07 PM #1
Mitsubishi Heavy R407c 20.0kw ducted indoor with controller RCD-H-S-E.
Controller set temp has been locked on 23degC - how can I unlock this?
Also when put on heat mode displays hot keep - anybody know what this means?
Thanks!
08-02-2011, 04:21 PM #2
Re: Mitsubishi Heavy R407c
You will have to take the controller apart - undo the screw first! Inside there is a group of dip switches that should be labeled, I cannot remember what ones there are - it has been a long time since I have seen one. There is also a line of jumper wires some of which may have been cut, again can't remember what does what.
The hot keep is a cold draft prevention thingy.
Andy
mitsubishi heavy ind fdc200vs
By stevos in forum Air ConditioningReplies: 6Last Post: 20-01-2011, 07:27 PM -
mitsubishi electric v mitsubishi heavy ind
By coolhibby1875 in forum Air ConditioningReplies: 8Last Post: 04-09-2009, 01:42 PM -
Please Help Mitsubishi Heavy Ind problem
By simplycooling in forum Air ConditioningReplies: 23Last Post: 02-03-2009, 11:18 PM -
Mitsubishi Heavy
By Krondor in forum Air ConditioningReplies: 7Last Post: 22-11-2007, 12:31 AM -
mitsubishi heavy
By ric in forum Air ConditioningReplies: 2Last Post: 01-09-2006, 11:18 PM
