Thread: fire dampers
08-02-2011, 12:05 PM #1
fire dampers
i'm a self employed AC / Refrigeration Engineer and i'm about to get involved with Offshore accomodation and workspace modules. A60, zone 1 + 2 Atex rated etc, Automatic fail safe fire dampers
The AC side of this is not an issue but as far as pressurisation fans and fire dampers go my knowledge is pretty limited. Does anyone have any advice on how to balance the fans and set up fire dampers? Any literature that i could maybe look up online? I want to make sure i'm as clued up as i can be before i get stuck in.
Any help would be very much appreciated.
08-02-2011, 07:25 PM #2
Re: fire dampers
I assume you are in the UK...but even if you are not...these people design and manufacture fire dampers and from my experience, they appear to be the biggest in the UK. Have a look around their site or e-mail them for additional info if you can't find it.
http://www.actionair.co.uk/right.html
When I worked on the offshore modules some years back, these people were specified suppliers.
08-02-2011, 09:32 PM #3
Re: fire dampers
There are quite a few manufacturers who make fire dampers, but the atex directive now requires that equipment in Haz areas is suitably certified to ATEX stadards.
We used to use blast dampers which are a fire and blast protection device. Trox used to make them but I don't know if they do now as many manufacturers backed off from manufacturing these devices due to the high standard spec of ATEX.
I recon if you do a search you'll find something useful
Here's one I found
http://www.offshore-technology.com/c...n-marine3.htmlReality is an elusion created by alcohol deficiency. Quaff and enjoy. [Yorkshire, UK]
actuators on dampers
By Johan2 in forum Air ConditioningReplies: 4Last Post: 04-01-2011, 01:01 AM -
Fire !!!!
By tony--1 in forum Chit Chat & Service StoriesReplies: 0Last Post: 03-12-2009, 10:21 PM -
Fire Run
By steve_k in forum Chit Chat & Service StoriesReplies: 6Last Post: 01-12-2008, 02:31 AM -
Vibration Dampers on Sabroe Compressors
By kelvin_27_84 in forum Industrial CompressorsReplies: 2Last Post: 11-05-2008, 05:55 PM -
Zone dampers in ducted system
By electronicsuk in forum Air ConditioningReplies: 12Last Post: 11-01-2008, 08:33 PM
