    Dec 2008
    West Yorkshire
    63
    Arrow ISO68 oil / R422D
    I need to convert a chiller from R22 to R422D or equivalent. The chiller has a semi-hermetic screw on it which runs on ISO68 oil. I know this oil is designed for ammonia use but will I be ok converting this system to R422D?
    Jun 2006
    South Coast
    278
    23
    Re: ISO68 oil / R422D
    Suggest you look up Duponts web site for Retrofit Information.
    3,853
    Have recently inheritted a dairy cooling system that had been converted from R22 to R422D, i had to replace two solenoid valves due to the o rings leaking.
    If and when i do any conversions from R22 in future i will be changing o rings or whole parts at the same time. Can't help much with your oil question...
    muddassarusa's Avatar
    muddassarusa Guest
    I can let you watch this may this help you about your question wish you good luck.
    http://www.youtube.com/watch?v=p2KIcZSVUf4
    Nov 2010
    The Netherlands
    64
    134
    14
    I agree with MS on this one, replacing all seals is a wise precaution. Having experience with the first wave of drop-in refrigerants, they did have a tendency to devour all forms of rubber in the system.
    Mar 2005
    638
    First thing to do is to contact the compressor manufacturer and see what requirements he may have for using the blend and what oil to use in the compressor. Once you know th eoil and refrigerant, you need to check the other elastomers in the system.
    Ken
    Jul 2008
    Houston Tx
    42
    Its fine use the oil thats the biggest selling point of that blend is no oil change and no valve changing
  1. Mop 29 / r422d
    By Grizzly in forum Refrigerants
    Last Post: 02-10-2010, 07:42 PM
  2. R22 to R422D Retrofit
    By dantheguru in forum Refrigerants
    Last Post: 21-07-2010, 11:35 AM
  3. R422d
    By jjthefridge in forum Supermarket Refrigeration
    Last Post: 19-05-2010, 10:22 PM
  4. R422d
    By chillled in forum Supermarket Refrigeration
    Last Post: 08-04-2009, 05:09 AM
  5. R422d ???????
    By moshman in forum Refrigerants
    Last Post: 08-08-2008, 07:25 PM
