Thread: carrier fault codes
05-09-2005, 08:35 AM #1
carrier fault codes
hi to you all , i have a carrier ducted ac system series 38yl i think and its giving me 3 flashes on a green led on the inside pcb any idears?
05-09-2005, 05:41 PM #2
Re: carrier fault codes
you have given the outdoor unit M/n (I think). Anyway 3 flashes usually means that the indoor unit coil thermistor is faulty
15-11-2005, 08:04 AM #3
thanks it is and a quick sol is to put a 47k ohm across s1 s2
19-07-2009, 12:48 PM #4
Could any one tell me how to re cover all refrigerant from a Daikin 3 pipe system.
thanks Paul
04-10-2009, 10:16 AM #5
Hi all, this is my first request for help!!!!!!!
I have a carrier a/c model 38 YLN-18A-703EJ-40 (wall mounted split) indoor unit is showing 4 flashes on green led. It is an old unit and I cant find any info on this one, any ideas?
Thanks in advance!
04-10-2009, 01:18 PM #6
a problem shared is a problem halved
04-10-2009, 02:29 PM #7
Many thanks iceman007 for your efforts, at least now I have somwhere to start from!
carrier fault codes
By mr saw in forum Air ConditioningReplies: 9Last Post: 30-06-2010, 03:31 PM -
carrier fault codes
By richelli in forum Trouble ShootingReplies: 5Last Post: 18-06-2010, 07:35 AM -
carrier chiller fault codes
By al in forum Air ConditioningReplies: 7Last Post: 20-07-2009, 10:10 PM -
Daikin fault codes
By Markie in forum Air ConditioningReplies: 16Last Post: 13-01-2009, 01:58 AM -
MHI, Sanyo & Fuijitsu Complete Fault Codes
By aeb200 in forum Air ConditioningReplies: 1Last Post: 16-11-2005, 01:11 PM
