    Mattster76's Avatar
    Mattster76 Guest
    LG GRS642AQ Cooling Problem
    I have a LG GRS642AQ (7 Years old) it has a freezer in top and fridge on the both, the freezer is working fine but the fridge is not cooling down properly, can any one help???
    3,856
    Re: LG GRS642AQ Cooling Problem
    Quote Originally Posted by Mattster76 View Post
    If its one of them new fangled frost free things, it could be that the passages the cold air goes down are blocked up with frost. The fix for this is turning it off for 24/48hrs with the doors propped open to allow the frost to melt and normal service to be resumed, or until if freezes up again if its a defrost heater or control issue that caused it to freeze up instead of the door not being shut properly once.
    Or it could be some thing else and you'll just be wasting 2 days. I can't tell from here.
    Jon
    Mattster76's Avatar
    Mattster76 Guest
    thanks Jon Ill try that, there no harm in trying. Ill let you know how it goes.
    Matt
    Jul 2006
    norfolk
    737
    check defrost sensor and defrost heater
  1. oil cooling problem
    By chichi in forum NH3
    Last Post: 15-03-2010, 09:00 AM
  2. Liebherr fridge sounds, cooling and LCD problem
    By bv1976 in forum Trouble Shooting
    Last Post: 03-03-2010, 11:31 AM
  3. Cooling problem with VRV REYQ24M7.
    By cool#9 in forum Air Conditioning
    Last Post: 07-02-2010, 12:20 PM
  4. LG heat pump problem
    By back2space in forum Heat Pumps
    Last Post: 01-02-2009, 11:23 PM
  5. Regulation of cooling capacity
    By npaisnel in forum Domestic
    Last Post: 08-02-2002, 11:22 PM
