Results 1 to 1 of 1
Thread: Oil recovery after burnout.
02-09-2005, 05:49 PM #1
Is it extremely necessary to recover every bit of oil after a compressor burnout in a small 10 ton portable chiller with a scroll compressor. I have already recovered 3qts of oil the book says I should be able to find 4. Is that last qt critical or can I just remove a qt from the new compressor, and use a nuetralizer to clean up the rest along with the proper filter driers?
Mark
Make a Recovery Unit
By shark26 in forum Tools and CalculatorsReplies: 12Last Post: 22-02-2009, 06:49 PM -
plate exchanger in heat recovery ventilator
By Lc_shi in forum New TechnologiesReplies: 1Last Post: 17-07-2007, 04:30 PM -
Linde Pack, Oil recovery system.
By buddy in forum Supermarket RefrigerationReplies: 26Last Post: 05-01-2007, 03:04 AM -
Recovery and vacuum equipment
By Larry2 in forum FundamentalsReplies: 2Last Post: 19-07-2006, 12:16 AM -
Heat recovery and aquifer heat/cold storage
By RicHoe in forum Supermarket RefrigerationReplies: 23Last Post: 23-06-2006, 01:24 AM
