Thread: daikin ducted
05-02-2011, 01:46 AM #1
daikin ducted
I have a problem with the outdoor unit of a ducted Daikin RY71FV1.THe condensor fan will not run and compressor cuts out on High pressure switch.The fan is O.K. & when manually run, [ie;bypass circuit board] the unit runs O.K. Does anyone know what can prevent the fan from running?
I suspect a faulty sensor or circuit board.Is it possible to get a service manual for this model ? [approx 10 yrs old ]
05-02-2011, 11:27 PM #2
Re: daikin ducted
are you getting voltage on the PCB?
07-02-2011, 01:40 AM #3
Re: daikin ducted
Connected fan seperate,ie bypassed pcb fan output] Have power to pcb & unit running 3 days now[ie;controlling temp]
Appears to be fan output not working only.
Programming Daikin Ducted A/C
By rx2 in forum Air ConditioningReplies: 0Last Post: 24-01-2010, 09:43 AM -
daikin ry140kuy1 ducted LP fault
By paul_h in forum Air ConditioningReplies: 27Last Post: 09-09-2009, 08:54 PM -
Daikin Ducted Commission Probs
By jdkmj in forum Technical DiscussionsReplies: 6Last Post: 23-11-2008, 08:21 PM -
Problem with ducted Daikin
By jutty in forum Trouble ShootingReplies: 8Last Post: 23-07-2007, 05:34 AM
