    ashwininventech's Avatar
    ashwininventech Guest
    How to determine the flow?
    Hello,
    I am trying to design cooling system for an electronic heat load of the 2.5 kW in a chamber.
    I need to supply air at 17 deg C to maintain the temperature of the air in the chamber at 20 deg C. (As per the specifications)
    The chamber is insulated.
    In this case how to determine the Air Flow?
    11,025
    Re: How to determine the flow?
    We need a few more details, as usual.
    Ambient air temperature
    Size of room
    Air Change Rate
    etc
    Thanks for the reply.
    Ambient air temp is 45 deg C (max)
    Size of the chamber is 520 mm (width) x 520 mm (Length) x 900 mm (Height)
    Nov 2010
    Germany
    120
    14
    Q=V*cp*ro*DT/3600
    From that
    V(air flow)=Q*3600/cp*DT*ro [m3/h]
    cp heat capacity of air
    ro density
    DT-your case 3K
    you allready have a Q=2.5kW so just change the units and that is it.
    And also you can do it according to the desired air change rate.
    Be careful about reading health books. You may die of a misprint.
    Apr 2009
    Panacea, Florida
    87
    Smile Re: How to determine the flow?
    KW = air flow * delta T*specific heat of air *density of air*conversion constants
    KW = L/s * ˚C * cal/gm˚C *gm/L* kw-hr/cal * s/hr
    for air, cal/gm˚C = .25, density gm/L =1.25
    s/hr = 3600, kw-hr/cal =1.163*10^-6
    so L/s = KW/(˚C * cal/gm˚C *gm/L* kw-hr/cal * s/hr )
    = 2.5/(3*.25*1.25*1.163*10^-6*3600)
    = 640 L/s
    This is the minimum air flow needed to absorb 2.5KW with a temperature rise of 3˚C. Any higher air flow will result in a chamber colder than 20˚C, ultimately approaching the 17˚C supply air temperature.
  1. Really weird refrigerant flow issue
    By paul_h in forum Air Conditioning
    Last Post: 13-04-2010, 05:13 PM
  2. flow switch connection
    By afeef in forum The Trail of Tears
    Last Post: 23-12-2009, 06:55 PM
  3. Flow Rate through Fan Coil Unit
    By deepu in forum Air Conditioning
    Last Post: 21-07-2009, 06:42 AM
  4. Capillary Tube Characteristics
    By Chef in forum Fundamentals
    Last Post: 10-03-2009, 01:03 PM
  5. Refrigerant flow rates/gas laws
    By budro in forum Technical Speculations
    Last Post: 24-10-2008, 03:12 AM
