Thread: panasonic/ daikin vrv2
01-02-2011, 08:55 PM #1
Hi people, hoping someone could help.. basically got a problem on a panasonic vrv2 (which is basically a daikin)! not got very far with panasonic tech.
whats happening is..... i have 11 indoors on the system, nearest the outdoor i have 2 indoors with their own controls which work fine, then the next 4 units down which have 2 controls to 2 units, these units do nothing, no heating or cooling at all. no faults on control, tried in test with no result. the next 2 units down are fine. then the next 2 units are icing up when turned off, unit furthest from condenser works fine!! hope this makes sense.
spoke to panasonic he reckons all expansion valves need replacing which i find unlikely? tried to recalibrate 1 valve by switching blue/yellow with no luck. forgot to mention.. turned off all units except 2 indoors which weren't doing anything, outdoor unit runs but still no performance on indoor units.
all help much appreciated
01-02-2011, 10:34 PM #2
Re: panasonic/ daikin vrv2
2 pipe or 3
can the outdoor detect all the indoors?
float switch disabling unit,fault codes inc previous ones in setting mode 41.
gas charge correct,operating pressures.
03-02-2011, 10:18 PM #3
I reckon it will be the electronic heads on the expansion devices.
Transmission wiring thickeness on Daikin VRV2
By rajeshsam in forum Air ConditioningReplies: 3Last Post: 12-01-2010, 01:21 PM -
Transmission wiring on Daikin VRV2
By Markie in forum Air ConditioningReplies: 19Last Post: 25-09-2009, 06:24 PM -
Daikin VRV2
By icecube51 in forum Trouble ShootingReplies: 4Last Post: 03-09-2009, 07:02 PM -
Panasonic Urban rebadged Daikin
By complete HVAC in forum Air ConditioningReplies: 0Last Post: 19-08-2009, 04:35 PM -
daikin vrv3 vrs vrv2
By transit 1 in forum Air ConditioningReplies: 2Last Post: 23-12-2007, 06:51 PM
