Results 1 to 1 of 1
Thread: heat exchangers and freezing
01-02-2011, 10:23 AM #1
Hi All,
I would appreciate your advice with regards to the heat exchangers for the office building, with vrv system designed for outside temp. -12C, inside t 22C, humidity 50%, but the outside temperature could get during the nights to -18C. They will be placed 8-10m inside the building. Are they going to freeze and if yes, for how long we will not have a fresh air? Do we need an additional heater for the fresh air? Is it sufficient to use a device with paper heat exchanger to lower the humidity and potential risk of freezing? thanks in advance
Addition of a heat pump to solar heating system
By rt29781 in forum Heat PumpsReplies: 24Last Post: 23-01-2010, 08:46 AM -
refrigerant to water heat exchanger
By knighty in forum CommercialReplies: 12Last Post: 16-06-2009, 03:33 AM -
Heat pumps freezing
By dkalasz in forum Trouble ShootingReplies: 21Last Post: 05-01-2008, 04:40 PM -
lab scale cooling of a high shear mixer
By Keith_99 in forum IndustrialReplies: 10Last Post: 17-01-2002, 08:37 PM
