Thread: Daikin vrv 3
31-01-2011, 04:54 PM #1
hi anybody out there heard of a L2 fault on a reyq10p vrv 3 system?
Hi anyone out there heard of a L 2 fault on daikin vrv 3 system
daikin vrv 3 system what does l two fault mean
31-01-2011, 06:49 PM #2
Re: Daikin vrv 3
You can download the VRVIII service document from the Daikin website if you register.
I've had a look though and L2 code isn't mentioned. Unless a Daikin guru posts here then you will need to call them.
Tail between my legs,
02-02-2011, 08:37 PM #3
Re: Daikin vrv 3
For an L2 code you need to ring Daikin Tech Help Desk 0845 6419200
02-02-2011, 09:17 PM #4
Re: Daikin vrv 3
Well, I did edit my post soon after I did it but it looks like it didn't work.
The L codes refer to faults with the inverter compressor. If you get a chance then maybe you could check through charging circuit, IPM, compressor...
faceless daikin
By quiet monkey in forum Air ConditioningReplies: 4Last Post: 27-01-2011, 11:33 AM -
Daikin not working... many problems
By stankovicv in forum Air ConditioningReplies: 26Last Post: 11-12-2010, 09:01 AM -
Mitsi City Multi VS Daikin VRV
By sumsor in forum FundamentalsReplies: 5Last Post: 14-07-2010, 05:54 PM -
Daikin AC parts from UK
By skel00 in forum Air ConditioningReplies: 5Last Post: 05-04-2009, 01:24 PM -
Fixing Daikin A3 Error
By Stuffy in forum Air ConditioningReplies: 3Last Post: 27-03-2009, 06:02 AM
