Thread: Need Help Fujitsu ASY12RSGCW
31-01-2011, 08:27 AM #1
Dear All,
This wall mount unit is working fine on cooling but as soon when i try to turn on heating indoor unit fins stop moving, light stay on it like indoor unit is pause and outdoor unit runs like normal.
Is anyone know what could be the problem?
Many Thanks
31-01-2011, 09:01 AM #2
Re: Need Help Fujitsu ASY12RSGCW
The indoor fins (fan) in heating mode only runs when the indoor coil is hot.
So faulty coil thermistor detecting the heat, or reversing valve operation in the outdoor (coil, valve, wiring) or system short of refrigerant.
If you're a tech that's easy things to check (is the indoor or piping cold? is there power at the reversing valve solenoid? what is the pressure in the pipings at the service valve? etc)
31-01-2011, 11:09 AM #3
Thanks Paul,
I will have a look again on coming weekend, I am not prof tech but I know lots of things in A/Cs.
02-02-2011, 12:09 PM #4
Does the system have a Pc Board with cold air prevention mode? Does this occur only at start up and it eventually come good or does it do this activity all the time?
02-02-2011, 07:05 PM #5
in heating mode the indoor fan will run only after a heated heat exchanger
11-02-2011, 09:12 AM #6
7258james: it work fine on cooling when i turn into heating mode green light stay on but fan dosent turn on.
luboboi: thanks for your info
paul_h: I still haven’t got chance to have a look again, Thanks
Thanks All
Fujitsu AOY90TPAMF
By andy c in forum Heat PumpsReplies: 6Last Post: 08-02-2010, 04:22 PM -
your opinons on fujitsu please
By acgibo in forum Air ConditioningReplies: 18Last Post: 26-08-2009, 05:06 PM -
fujitsu wall mount volt free relay
By mike live in forum Air ConditioningReplies: 3Last Post: 09-04-2009, 08:26 PM -
Fujitsu PCB
By gwilliamson in forum Air ConditioningReplies: 6Last Post: 10-09-2008, 10:27 PM -
Fujitsu or not?
By LRAC in forum Air ConditioningReplies: 14Last Post: 29-08-2007, 09:45 AM
