Thread: finding tonnage of dx evap
31-01-2011, 12:26 AM #1
how can i figure out the design tonnage of my dx evap?
31-01-2011, 01:22 AM #2
Re: finding tonnage of dx evap
Hi blazer.
a little bit more info is required for an informative comment.
1/ refrigerant 2/ operating pressures. 3/ application. 4/ compressor details. 5/ evaporator details. 6/ txv details.
31-01-2011, 02:55 AM #3
1.r-22
2. Low 60psi, high 220psi
3.comfort
31-01-2011, 02:58 AM #4
3.comfort cooling
4. 15 ton recip compressor,480 3phase 25 amp (two comps per evap)
5. all i know is 2 comps per evap
6. tev-15-ga (15ton)
12-05-2011, 08:44 PM #5
evap heat load (btu / hr) = mass flow (lbs / hr) * latent heat of evap for r22 at evap press/temp (btu / lb)
take heat load (btu / hr) and divide by 12000 to get tonnage.
13-05-2011, 11:17 AM #6
2x 15 ton compressors = 30 ton evaporator
Bad Evap?
By Telecaster1 in forum CommercialReplies: 6Last Post: 07-09-2010, 12:34 AM -
Enviromental Chamber Cold Room - 1 evap freezes
By sig83 in forum Trouble ShootingReplies: 1Last Post: 19-06-2010, 06:49 PM -
iced up evap coil
By wilks in forum FundamentalsReplies: 6Last Post: 31-08-2007, 09:15 PM -
how to wire in pause before evap fan kicks in after defrost ?
By knighty in forum ElectricalReplies: 10Last Post: 21-01-2007, 01:08 AM -
Evap motor no come on
By Apprentice in forum Technical DiscussionsReplies: 13Last Post: 04-12-2003, 04:07 PM
