Results 1 to 2 of 2
Thread: Smeg FAB 30 always running
29-01-2011, 01:22 PM #1
Hi, we have a fab30 smeg and it is having one major issue.
The fridge is always cooling, and it is freezing things (regardless of settings), the freezer is fine, and it makes an increasingly loud noise the longer it is on for.
The one thing i have noticed is there is a small gap in the door seal on the bottom right hand side of the door (see below image).
Does anyone have any thoughts?
(i cant post the image as too new, so instead here is an altered url version of the image)
[eh tee tee pee and colons] dl.dropbox[insert dot com]/u/12202295/photo.JPG
29-01-2011, 02:33 PM #2
Re: Smeg FAB 30 always running
hi, sounds like your thermostat is buggered , and you need a new door seal, and the load noise = could be short of gas HELP THE ECONAMY BUY A NEW FRIDGE, sedgy,
3 MAJOR ISSUES
Amana SRD25S5W: compressor with intermittent cooling while running under full voltage
By im_dragon in forum DomesticReplies: 3Last Post: 29-10-2009, 09:41 PM -
Typical running amps
By acnerd in forum FundamentalsReplies: 8Last Post: 08-09-2009, 11:54 PM -
Problems with compressor running too cold
By abrando1 in forum Trouble ShootingReplies: 8Last Post: 12-05-2009, 10:08 PM -
Walkin cooler running to warm need help
By The Butcher in forum Trouble ShootingReplies: 7Last Post: 03-08-2007, 09:19 PM -
Running Costs
By Abe in forum Air ConditioningReplies: 4Last Post: 09-04-2007, 12:58 AM
