Thread: City Multi
29-01-2011, 09:09 AM #1
City Multi
Hi all,
I've just intalled a city multi at a store, one outdoor,4 cassetse,and one controller.
the question i have is there any way of locking the temp set point on the controller to stop the staff at the store from messing about with it
Any help much appreciated
mant thanks.
29-01-2011, 09:35 AM #2
Re: City Multi
on a par21 The following settings can be made.
no1 :All buttons except for the [ON/OFF] button are locked.
no2 :All buttons are locked.
OFF (default) :No buttons are locked.
* To activate this operation lock function on the normal screen, hold down theON/OFF button for two seconds while
holding down the FILTER ( ) button
29-01-2011, 09:39 AM #3
Re: City Multi
Or if you have a Par 27 to lock all the buttons other then the on/off button,
Press the [on/off] button for 2 seconds whilst holding down the [FILTER] button.
Alternatively you could also set a temperature range limit on the controller.The difference between genius and stupidity is that genius has its limits.
Marc
29-01-2011, 09:42 AM #4
Re: City Multi
temperature limit settings are
(1) While pressing theMODE button, press the ON/OFF button for two seconds to activate the remote controller’s
function selection mode.
(2) Press the MODE button to select FUNCTION
SELECTION on the screen (at ).
[Display ]
(3) Press the MENU button to select LIMIT TEMP
FUNCTION on the screen (at ).
* If a setting change was made previously, the mode that was set (one of the modes shown in step (4)) will be displayed.
(4) Press the ON/OFF button to select the mode for which temperature range limit setting is to be made.
[Display ]
* No operation modes will be displayed if auto mode has been set to OFF
Press the button to select lower limit or upper limit.
Lower limit blinks. Upper limit blinks.
[Display ]
(6) Press the [TEMP] buttons ( and ) to set the desired temperature setting range.
[Setting example for lower limit]
(7) While pressing theMODE button, press the ON/OFF button for two seconds to return to normal mode. Setting is
now complete.
* If you press the ON/OFF button before the MODE button, the settings you have made will be cancelled.
* If an attempt is made to set a temperature outside the range when the temperature range limit function is in use, “LIMIT
TEMP FUNCTION” will blink.
29-01-2011, 08:44 PM #5
Re: City Multi
thanks everyone for the replies, will give it a go on monday.
cheers
Multi City
By spikybm in forum Trouble ShootingReplies: 4Last Post: 03-09-2010, 08:53 PM -
RS44 R424a in City Multi
By Collie in forum RefrigerantsReplies: 2Last Post: 22-07-2010, 05:56 PM -
City Multi Undersized
By MOVHVAC in forum Air ConditioningReplies: 3Last Post: 20-07-2010, 06:46 PM -
City Multi Faults
By Collie in forum Air ConditioningReplies: 2Last Post: 22-06-2010, 06:13 PM -
Need input on City Multi
By TDfromNY in forum Air ConditioningReplies: 4Last Post: 09-06-2006, 03:31 AM
