    mrgbfan's Avatar
    mrgbfan Guest
    Freezer/Cooler Question
    I am not an engineer, but I do own an industrial novelty display type freezer. It is a Masterbilt GT40. I need to know if it would be OK for me to change the thermostat in the unit and convert it to a cooler? I was warned that this may shorten the life of the compressor due to 'short cycling' it.
    Aug 2005
    manchester
    47
    Re: Freezer/Cooler Question
    It does depend on the gas.
    Because when it is used as a freezer, the gas will be coming back to the compressor to help cool down the head. So it might not be a good idea. Try and find out what the gas is. I think it will be on R404a.
    :eek:
    mrgbfan's Avatar
    mrgbfan Guest
    Yes. The spec sheet says it is R404a .
    Jul 2005
    Malaysia
    44
    66
    If it is R404a gas, then it will have sufficient ref mass flow to cool compressor head. However, is the condenser sufficiently large enough to cater for mid temp capacity?
    May need to monitor high side pressure...
  1. Newbie with a question
    By AcidSlasher in forum Fundamentals
    Last Post: 07-03-2006, 11:20 AM
  2. quizy type question thingy
    By rbartlett in forum Chit Chat & Service Stories
    Last Post: 06-02-2006, 09:22 PM
  3. A/C Question
    By Latte in forum Air Conditioning
    Last Post: 24-08-2004, 08:19 PM
  4. Urgent, Kirchoff question
    By Peter_1 in forum Fundamentals
    Last Post: 20-01-2004, 03:12 PM
  5. Direct Energy Consumption Question
    By v8dve in forum Fundamentals
    Last Post: 05-04-2003, 03:31 AM
