Thread: Any Ideas??
26-01-2011, 04:06 PM #1
Any Ideas??
Think i know the answer to this one but didnt know whether any one had any ideas?
Daikin single split losing pressure located leak on outdoor unit liquid side valve.
valve core (Shreadar)(Spelling!) had a been bent and threfore pin wasent sitting straight.
Pumped system down and attempted to remove existing valve core but the thread snapped all the way round thus not letting me remove the valve core
Any ideas or is it just a new valve jobby?
TA.
26-01-2011, 11:28 PM #2
Re: Any Ideas??
A Daikin will probably have a high side access port inside the casing so just refit the port cover, ensuring a good seal, and label it as a damaged Schraeder - do not use.
27-01-2011, 07:16 PM #3
Re: Any Ideas??
flare a new schyder on over the top of the damaged one, great trick pulled me out loadsa times
27-01-2011, 07:22 PM #4
Re: Any Ideas??
hi av,
would have used a shrader extraction tool to change it with the gas in the system,
regards sedgy
27-01-2011, 07:32 PM #5
Ideas Needed For Cooling My Glass Blowing Studio
By JontheFisherman in forum Air ConditioningReplies: 17Last Post: 28-04-2011, 01:04 AM -
Daikin split problem (any ideas)
By airconjohn in forum Air ConditioningReplies: 14Last Post: 17-02-2008, 08:40 PM -
need 12 volt car AC ideas
By ayaz in forum TransportReplies: 5Last Post: 24-07-2007, 03:39 AM -
Need ideas !!!
By zvikard in forum Technical DiscussionsReplies: 5Last Post: 17-08-2006, 08:34 PM
