Thread: Deli Case
25-01-2011, 09:19 PM #1
Deli Case
I have a Deli case that is drying the cold meat out after 24hr. Is this caused from the Tx valve over feeding and a low superheat? I am unsure whether a low superheat or a valve that starves the coil and has a longer refrigerated cycle time would dry the stock out.
25-01-2011, 11:04 PM #2
26-01-2011, 12:52 AM #3
Re: Deli Case
Deli cases can suffer form light burn as well,,,,,,if you use standard tubes they will discolour cut meats,,,,are you sure it's low humidity,,,it may be a light issue.If the case is low on humidity you can increase %RH by fitting suction solenoid for temp control and defrost,,,the refrigerant keeps the coil pressure up and increases humidity,a pumpdown systen should not be used in deli cases.Lawrie
LawrieRemember we are here for a good time, not a long time.
Trust me i'm a Fridgy.
Coated Service Deli Coils
By DocFreeze in forum Supermarket RefrigerationReplies: 8Last Post: 18-01-2011, 08:30 AM -
Multi deck island deli case
By joe magee in forum Supermarket RefrigerationReplies: 7Last Post: 08-11-2010, 03:42 PM -
Isa Gelato Case at -18
By Gridley13 in forum CommercialReplies: 16Last Post: 05-04-2010, 12:06 AM -
a frozen book display case
By tempo in forum Technical DiscussionsReplies: 3Last Post: 15-08-2008, 07:20 PM -
cpc case controller
By dingo in forum Trouble ShootingReplies: 4Last Post: 09-04-2008, 09:35 AM
